Old 01-21-2011
stantale is on a distinguished road
forced air heater duct material
Hi All,
we just installed a toyoset forced air heater, and I'm looking for the right material to make the duct out of - I really don't like flexible aluminum dryer tube since it's so flimsy, on the other hand I don't know what kind of rubber/plastic to use because it gets really hot (haven't measured but too hot to touch near the heater.)
Any recommendations on tube type that will insulate enough and withstand the heat? It's around 3" I.D.
Engine exhaust material is a bit on the expensive side ;-)
Old 01-21-2011
mitiempo's Avatar
Most heaters I am aware of come with duct material or have the proper ducting as an option. Sure Marine in Seattle has everything you need as well as great heater information - their specialty. Sure Marine
Brian
Old 01-21-2011
MacGyverRI's Avatar
MacGyverRI is on a distinguished road
You could use some galvanized pipe (like stove pipe but used for ducts) along w/ some elbows and wrap that w/ the 1/2" or so duct fiberglass that comes on a roll.
They also make a commercial insulated flexible duct (used for cooling/heating) that has the foil on both inner and outer w/ fiberglass on the inside and a wire spiral for strength.
Ken, East Prov., R.I. Bootlegger, PY26 Paceship
If you like my posts, or they were helpful, please click the "scales" icon on top right to add Rep points.
Old 01-21-2011
mitiempo's Avatar
The proper ducting is available at the link I posted and anywhere that sells a forced air furnace for marine use.
A "MacGyver" type solution is only a good idea if the proper ducting is not available. Galvanized pipe?
Brian
Old 01-21-2011
MacGyverRI's Avatar
I gave an alternative solution by the $15 a foot stainless flex was expensive statement....
He's probably gonna have a heart attack w/ the $40-50+? a foot (evidenced by "call for price")...
Old 01-22-2011
mitiempo's Avatar
The proper ducting is not very expensive. The price list below is from Great Lakes Marine Specialties in Minneapolis. 90mm ducting is just over $5/ft and some other accessories are listed as well. These are for Webasto heaters. There is also 60 mm ducting at about $3.50/ft.
Best to deal with a heater specialist.
Brian
duct tape sailboat scottyt General Discussion (sailing related) 6 10-23-2009 11:57 AM
Duct Tape Removal labestia Gear & Maintenance 10 08-26-2009 09:35 PM
AC and Heat Duct Work? 1970Columbia34 Gear & Maintenance 14 01-28-2007 12:20 AM
Forced to Champaign SailinCowboy General Discussion (sailing related) 3 07-19-2006 03:30 PM
installing duct system for diesel heater and air conditioner levenezia Gear & Maintenance 1 09-25-2004 03:20 AM
