Old 01-23-2011
Exiles is on a distinguished road
Who knows about diesel outboard engines?
Hi we are planning a voyage this summer to one of the most remote places in the world and will travel thousands of nuatical miles between areas where we can get fuel. As such we will be carrying lots of diesel and would like to have a 9hp or so diesel outboard.
Does any one know of any reliable Diesel outboard engines?
Does any one know how reliable and durable they are?
I f you want more info on our voyage to the top of our planet please feel free to look around our site
Northwest passage on a shoestring
Thank you!!!
Old 01-23-2011
sawingknots's Avatar
sawingknots is on a distinguished road
i wouldn't even consider a offshore passage without a inboard diesel,a outboard simply isn't as efficient or reliable as a inboard also a outboard tends to lift out of the water in large swells,just imagine really wild seas,actually i use a inboard diesel and have a stern mounted outboard for [just in case] also you will need to use your sails 90+% of the time[you can only carry so much fuel
Old 01-23-2011
Yanmar makes a diesel outboard, but they're heavy, noisy and not very reliable IMHO.
Old 01-23-2011
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
Um...actually, according to the Yanmar website, they do not offer these anymore.
Superceded
Bummer. I was very curious about them.
S/V Old Shoes
1973 Pearson 30 #255
Old 01-23-2011
LakeSuperiorGeezer's Avatar
LakeSuperiorGeezer is on a distinguished road
Looks like an extra long shaft gasoline 4 cycle would be the way to go for economy as with the same amount of gasoline, you go three miles instead of two miles as with a two cycle if it has a carburetor. If two cycle and direct injection, the economy should be similar to the 4 cycle. The Yanmar came in 36 and 27 horsepower sizes so even used; they would not fit your needs. There must be a reason for the lack of the development of diesel outboards.
Old 01-23-2011
Very simple, diesel engines operate at much higher compression ratios and as such need to have a much heavier engine block. That makes them far heavier than their gasoline counterparts for the same horsepower, and that gives them a relatively poor power to weight ratio....they're also very noisy.
Old 01-24-2011
Thanks all! I heard that there is a Chinese company that makes 8-9hp but can not locate it.
The reason we want a diesel outboard is since we will have so many hundreds of litres on board and if our main inboard deisel breaks down which is a possibility since it is a 1976 we can use the outboard as our back up.
Old 01-24-2011
aa3jy is on a distinguished road
YouTube - DIESEL OUTBOARD MOTOR TYPES in PRODUCTION
Old 01-24-2011
tommays's Avatar
There more common in the third world not so much here
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 01-24-2011
Getting an outboard diesel started in cold weather without any pre-warming like you could with an inboard would be a problem. Inboard diesels are generally reliable with clean fuel and good compression.
Beginner's guide to outboard engines? silverbranch Gear & Maintenance 5 06-01-2009 05:45 PM
Price for new diesel engines jr438234606 Gear & Maintenance 22 04-18-2008 11:27 AM
transmission oil for diesel engines pegasus1457 Gear & Maintenance 7 10-25-2007 12:18 PM
Diesel & Gas Engines? oceanmaui Gear & Maintenance 5 10-24-2004 07:40 PM
New diesel engines Marktesno General Discussion (sailing related) 4 03-06-2001 02:28 PM
