Dinghy repair - SailNet Community
post #1 of 7 Old 01-23-2011 Thread Starter
Kiltmadoc's Avatar
Question Dinghy repair
We have an OLD PVC dinghy that we bought from craiglslist. The first time I took it out, the transom tore loose from the PVC in two spots. I have been told that I can try JB weld to fix it. But, realistically, is this a repair to try? Or should I cut my losses and just buy a new dinghy? The new dinghy appeals to me since the wife and 4 year old will be traveling on the dinghy as well.
Advice, ideas, suggestions, and the occasional "i told you so" about buying on craigslist are all appreciated.
Kiltmadoc is offline
post #2 of 7 Old 01-23-2011
Umm... I would just bite the bullet and buy a new HYPALON dinghy. The PVC ones are relatively short-lived unless well protected from the sun compared to a Hypalon one.
sailingdog is offline
post #3 of 7 Old 01-23-2011
poopdeckpappy's Avatar
bite the bullet, especially with the wife & 4 yr old aboard
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #4 of 7 Old 01-24-2011 Thread Starter
Kiltmadoc's Avatar
OK, got it. Now, where can I get an inexpensive hypalon dinghy? They all seem to be $1000.00+
post #5 of 7 Old 01-24-2011
Your best bet might be the Defender spring sale. They usually have very good deals then.
post #6 of 7 Old 01-24-2011
remetau's Avatar
You can have it professionally fixed. The glue used for PVC only lasts about 2 to 3 years, but it is cheaper than buying a new one.
We have a WM Zodiac 310 that we just had fixed again. This is the second time that we had it done, both within the 5 years of the warranty from Zodiac so it was free.
Don & Diana
sv Re Metau an HC33t
remetau is offline
post #7 of 7 Old 01-24-2011
If the PVC of the transom is that bad, the PVC material is probably not much better, and repairing it is throwing good money away.
Good tip for hypalon dinghy repair... SoulVoyage Gear & Maintenance 11 09-24-2013 07:41 PM
Hypalon Dinghy Repair curtandsandi Gear & Maintenance 2 02-05-2010 11:23 AM
Permanent Dinghy Engine Repair Solution LarryandSusanMacDonald Gear & Maintenance 8 12-03-2009 09:51 AM
Dinghy repair adhesive? CellNav Gear & Maintenance 3 11-13-2008 10:36 PM
The continuing saga of BJ's dinghy repair attempt.. beej67 Gear & Maintenance 4 08-13-2008 10:30 PM
