Frozen bilges - Page 2 - SailNet Community
post #11 of 16 Old 01-24-2011
Senior Slacker
SlowButSteady's Avatar
When you put the space heater on, did you also use a small fan to blow the warm air down into the bilge? Without forcing the (lighter) warm air down there, the (heavier) cooler air in the bilge has no reason to go anywhere and convection/diffusion of the heat might not be enough to warm things up.
SlowButSteady is offline
post #12 of 16 Old 01-24-2011
LakeSuperiorGeezer's Avatar
Here is the pure strength propylene glycol based antifreeze intended for cars: SIERRA Antifreeze The freezing point of CaCl2 brine is -40F with a concentration of 23.3%. For regular table salt, NaCl, at a concentration of about 24%, the the freezing point is 0F.
LakeSuperiorGeezer is offline
post #13 of 16 Old 01-24-2011 Thread Starter
A little frozen water in the bilge wouldn't even get my attention. I did put a full gallon of -100f antifreeze in the empty bilge before I left it. The problem is that water comes down the mast in remarkable quantity and fully overwhelms the bilge and dilutes the AF. The boat does have a full cover on it. It has not been uncommon for me to come and handpump 20 gallons of water out of the bilge each month. The level is probably twice that high now, but frozen solid.
The water starts to back up across bilge compartments and has now penetrated the genset locker. The frozen water in the genset has covered some hoses and insulated electrical wiring and is just about to be high enough to get into the genset cabinet itself.
The primary bilge pump is well above the bilge itself, with only an intake hose down in the bilge. The backup pump is fully submerged under the ice. That cant' be good.
Rock salt seems like it would leave corrosive residue behind. I will have to look into a non-corrosive chemical deicer.
Another suggestion I received was to heat up or boil some -100f antifreeze and pour over the ice. It would melt, mix and keep all from refreezing while I pump overboard. First, I have to check to see if heating antifreeze is a good idea and it isn't flamable. Secondly, that will get expensive as it will take dozens of gallons that will just go straight overboard.
Thanks for the ideas.
Minnewaska is offline
post #14 of 16 Old 01-24-2011
Do you have this problem every winter?
orient is offline
post #15 of 16 Old 01-25-2011 Thread Starter
No. I have typically been able to get there shortly after it rains to pump, but it has rained several times, then immediately dropped below freezing temps this year. If it were to stay cold, it would snow, which is not an issue. If it stays just above freezing, its still liquid and I can deal with it. Too much back and forth this year, with some serious deep freezes.
post #16 of 16 Old 01-25-2011
at this point go with rock salt, get it melted and out then rinse to get rid of the extra salt. you could also go get a few heat tape setups and drop them in the bilge, they should slowly melt the ice thats there, then stop any other water from freezing.
but the above means nothing if you dont have power.
scottyt is offline
Cleaning nasty greasy bilges? Zogumwesterly Gear & Maintenance 32 08-25-2009 12:43 PM
Frozen Prop thisisus Gear & Maintenance 16 04-15-2009 10:45 PM
hello from the frozen north johndanicic Introduce Yourself 9 01-16-2009 11:47 AM
MacDonald Douglas Fleet: Bilges @ Sail Blogs NewsReader News Feeds 0 04-09-2006 02:15 AM
Frozen Thru Haul girardot Gear & Maintenance 1 01-25-2001 02:57 PM
