Old 01-24-2011
Minnewaska will become famous soon enough
Frozen bilges
Is it my imagination, or has it been far below freezing more often in RI this winter? Of course, that has been interrupted by a day of rain here and there and my bilges keep filling (mast penetration) and then freezing.
I am usually able to get there during a thaw and hand pump it out, but timing has been impossible for the last couple of months. I'm getting a bit concerned about the genset, which has the water beginning to reach its base and there is rain forecast for this week again, then right back to freezing.
I tried to heat the cabin with a space heater this weekend. I left it on for hours but it barely melted a film on top of the ice. I suspected this, as the hull is a huge heat sink at the moment.
Any tricks out there to defrost and pump frozen bilges? I have a kerosene heater that would make it a sauna in there, but not crazy about the carbon monoxide nor the exhaust soot in the cabin.
  #2
Old 01-24-2011
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
I hate to say it, but you probably have to climb down in there with a hair dryer and mop it out with a sponge a little at a time.
Where's the water getting in? I realize that it's too cold for bedding compounds to cure, but maybe you can cover that area or something?
My port jib track needs rebedding so the rain seeps in, runs down the quarterberth liner and into the bilge. Luckily, all the precipitation has been frozen so once I mopped out the bilge, it's stayed dry.
Is it possible to lay down butyl tape and then heat it with a hair dryer to get it to ooze into place properly?
S/V Old Shoes
1973 Pearson 30 #255
  #3
Old 01-24-2011
FishSticks's Avatar
Old Gaffer
FishSticks is on a distinguished road
Rock salt
Never sail closer to the wind in degrees than your age
  #4
Old 01-24-2011
Rock salt in the bilge is one idea. Another is to use a chemical de-icer and then pump out the ice slurry when the ice melts.
  #5
Old 01-24-2011
omaho5 is on a distinguished road
If all else fails, you could go to an RV dealer and inquire about the "enviromentally safe" Anti freeze used to winterize RV's.
Mix an appropriate amount with the water and pump it out in spring.
Dangers would be any deletarious chemical effects to the FG.
  #6
Old 01-24-2011
LakeSuperiorGeezer's Avatar
LakeSuperiorGeezer is on a distinguished road
Antifreeze & Fiberglass
Probably not a problem since modern car radiators have plastic fiberglass tanks on each end, but there are different types of plastic. You could mix a bit of fiberglass with antifreeze and see what happens.
  #7
Old 01-24-2011
The non-toxic antifreeze, at least the stuff commonly found in the RV and marine supply stores is designed not to be diluted and its effectiveness diminishes rapidly when diluted. It doesn't harm fiberglass to any degree.
  #8
Old 01-24-2011
ereiss is on a distinguished road
frozen bilges
What's the downside of having an inch or two of ice in the bilge?
Ed Reiss
Being There
Freedom F38 #154
out of Marion, MA
  #9
Old 01-24-2011
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
It could freeze, expand and damage the bilge. Most boats won't have any issues with a little ice, but I'd suspect if you get enough in there.... it could be really expensive.
Merit 25 # 764 "Audrey"
  #10
Old 01-24-2011
THEFRENCHA is on a distinguished road
Salt
Happens a lot here in Boston
I use salt And antifreeze
After 6 hours the salt will have melted the ice and then the Anti freeze kicks in if you cannot pump out immediately If possible As soon as melted just pump out with a manual pump into a bucket and throw overboard Add fresh anti freeze in the bilge
You may post attachments
You may edit your posts
Cleaning nasty greasy bilges? Zogumwesterly Gear & Maintenance 32 08-25-2009 12:43 PM
Frozen Prop thisisus Gear & Maintenance 16 04-15-2009 10:45 PM
hello from the frozen north johndanicic Introduce Yourself 9 01-16-2009 11:47 AM
MacDonald Douglas Fleet: Bilges @ Sail Blogs NewsReader News Feeds 0 04-09-2006 02:15 AM
Frozen Thru Haul girardot Gear & Maintenance 1 01-25-2001 02:57 PM
SEO by vBSEO 3.6.1
