Whisker Pole Fittings - SailNet Community
Blogs
Old 06-05-2003
Thermal is on a distinguished road
One of end fittings on my whisker pole isn''t working very well any more so I need to remove it and either repair or replace it. Have seen the fittings at West Marine (pretty big bucks for a simple casting) and it looks like they''re just pressed into the end of the aluminum pole, so the only way to remove it would be to cut off the end of the pole. Has anyone ever removed or replaced one of these things?
Old 06-06-2003
RichH's Avatar
RichH will become famous soon enough
Why not take it to a machinist who ''specializes in aluminum'' and discuss to ''overhaul'' it. Re-hab is usually a fraction of ''new''/part replacment.
If the end fitting has been there for a loooooong time ... you usually have to cut it off. Most ''re-habs'' dont have to go this far.
Old 06-07-2003
chris1514 is on a distinguished road
It''s pretty easy to remove. Wrap a cloth around it to protect the aluminum and put it in a vice. Take an aceteline torch and heat the end section of the pole. This will partially melt the epoxy that keeps the end fitting in and you can remove it by twisting it out of the pole with vice grips or some other tool.
Old 07-27-2003
sailingbauble is on a distinguished road
You seem to be saying that it''s working, but not as well as you would like. Before doing anything more drastic, I''d give it a few good soakings with WD 40 or equivilent. Perhaps all you have is some corrosion or goop that need to be disolved. If that doesn''t work, then proceed with major surgery.
Old 07-28-2003
mikehoyt's Avatar
mikehoyt is on a distinguished road
What size pole and boat do you have?
If it is the 6-12'' pole or the smaller one then it is easy and cheap.
In that case you can just cit off teh last inch of pole with a hacksaw and epoxy the new fitting in place. I did that successfully when one of my ends broke.
If you have a much larger pole then the end fittings are much more expensive and it is worth the bother of fixing the current in place end.
My 2 cents
Mike
Whisker Pole Length mikehoyt Racing 1 07-08-2004 09:18 AM
Inexpensive Whisker Pole Stormer Gear & Maintenance 1 03-08-2003 07:11 AM
Whisker Poles RichardElliott Gear & Maintenance 1 02-11-2003 11:27 AM
whisker pole mikehoyt Racing 10 01-03-2003 06:13 PM
Whisker Pole vs Cruising Spinnaker r2straebel Gear & Maintenance 5 01-24-2002 09:25 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
