Old 01-26-2011
Madhatter23's Avatar
Madhatter23 is on a distinguished road
Jib... one line or two?
I am new to sailing, and am looking to replace the sheets on the boat I just bought I have been reading the forums, and am wondering...Should I use one or two separate sheets to the jib? I plan on using a soft shackle to attach the sheet(s), which brings up another question...It looks like the soft shackle is made from a single braid line, is that right? I am not looking to race (yet), and hopefully won't have to change sails in a hurry, so it seems like a single line looped in the middle would be better than 2 separate.
Old 01-26-2011
tommays's Avatar
I have done the single line on the J24 and it works with no great advantage over two lines and the disadvantage of not being able to remove one of the lines if it becomes fouled
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 01-26-2011
Of course, if you're looking to use soft shackles...then you could seize an eye in the middle of a single long line and use it for both sheets and then connect it to the sail using a soft shackle.
Old 01-26-2011
centaursailor's Avatar
Senior in age only!!!
centaursailor is on a distinguished road
Exclamation
Normal set up is two seperate lines. Tie a bowline in each, easily undone if necessary and no additional piece of metal to smack you when, not if, the sail gets away at some stage. Raceing not for me.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
Old 01-26-2011
fordo is on a distinguished road
Use two lines attached with bowlines to the jib. if you just have one line it is difficult to detach the line from the sail when the sheet gets jammed or tangled, as Tommays said. Also, if you use one line you can't switch it end for end to change the wear pattern to extend its life. Except on a small dinghy I can see no advantage to using one line over two.
Old 01-26-2011
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
Two lines with bowlines are preferable but a single line can also be used with a running bowline as an alternative. The advantage of this knot is that it can be untied like a simple bowline.
Old 01-26-2011
thehardaground's Avatar
thehardaground is on a distinguished road
Personally I've used a single line for lots of years. Didn't really like the bulkiness of two bowlines, plus you could sheet almost to the clew of the sail, plus if you aren't good at knots, there isn't much to worry about. Since smaller sails usually need thicker lines for sheets I had a set on each sail. The attachment "knot" when using a single line is called a luggage tag.
Old 01-26-2011
jackdale's Avatar
jackdale will become famous soon enough
lark's head or cow hitch
I am of the 2 line school of thought a la fordo.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 01-26-2011
ardoin's Avatar
ardoin is on a distinguished road
Lark's head / cow hitch (aka cow hitch) have a problem on bigger sails - they will slip. Also if one side ever breaks, the jib could slip right out of the sheet. If you have a big boat and want to go with a single line, use an Alpine Butterfly - you will have to tie it "off the bite" or whatever that term is. I put a cow hitch followed by an Alpine Butterfly on mine. The first helps prevent chafe on the Alpine Butterfly.
This configuration make it easier for me to tack the Jib through the slot on a cutter rig.
Cy
S/V Music
MASON 44
Old 01-27-2011
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
I've got a pretty desent size head sail on our tayana and I use a single sheet w/ larks head, did the same on our last boat also, never had a issue, has never slipped but then, I haven't had to deal with a break either
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
32-26 water line rockybucci Island Packet 4 07-09-2007 08:05 PM
Stern line. Gulfislander Gear & Maintenance 5 05-28-2007 01:20 AM
Line Choice for Single-Line Reefing lmitchell Gear & Maintenance 6 04-12-2007 01:38 PM
The best line to buy superdave Gear & Maintenance 4 02-09-2007 11:14 PM
Shorter Single Line Reef Line dnseal Gear & Maintenance 6 11-26-2006 05:58 PM
