01-29-2011
Just remember, most rudder shafts aren't just a straight shaft. They're welded to a web that is the framing the rudder is built around. Without the web, the rudder quadrant has no leverage on the rudder blade, and the chance that the rudder blade would just spin around the shaft is almost guaranteed.
As for how to protect the rudder.. stay in DEEPER WATER.
Originally Posted by w1651
Hunter 37 Rudder
Looking at a hunter 37 with a bent rudder. Cheapest one I could find online was about $1500.00.
I was thinking about taking it out since the boat is on the hard and splitting the rudder at the spade and removing the shaft. Getting a shaft of stainless to replace it and having it machined to original specs. putting it back into the spade and fiber glassing it together again.
Has anyone ever done this?
Also after I did this how could I protect the rudder so it didn't happen again?
Thanks in Advance
