Old 01-30-2011
labestia is on a distinguished road
Removing Clear Epoxy from Gelcoat
Hello:
Recently dropped some 2part clear epoxy on the gel-coat of my deck; didn't notice till the next day.
Any suggestions on how to remove it?
La Bestia
Old 01-30-2011
scottyt is on a distinguished road
try to peel it carefully. then scrap it with a blade, the nice thing about straight epoxy is its brittle, it should scrap off nicely, but carefully.
Old 01-30-2011
IF it isn't on the non-skid, a plastic razor blade would do the trick nicely.
Old 01-30-2011
RichH's Avatar
RichH will become famous soon enough
A single edge razor blade held almost parallel with the surface will help ... be sure to 'saw it off' with the blade to insure that you dont 'pop' the gel. You may need to (power) buff the gel when done to remove any small scratches from the sawing with the blade.
If you have regularly waxed the gel it will be much easier to remove the epoxy 'splats'.
Old 01-30-2011
If you use a steel razor blade, be sure you round/dull the corners with a file or sandpaper, so that they don't gouge the gelcoat.
Old 01-30-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Progressive Epoxy has something they call TA 661 (I believe that it's some sort of long chain alcohol) that acts as a solvent for uncured epoxy, and will supposedly help to remove recently cured epoxy (probably because the polymerization, or curing, isn't complete). It's probably too late to use it in this case, however.
Removing old epoxy sailingmum Gear & Maintenance 7 08-13-2010 01:23 PM
Removing paint from Gelcoat lrak Gear & Maintenance 11 11-08-2008 11:29 AM
gelcoat or not to gelcoat? marcusn Gear & Maintenance 2 05-30-2008 02:44 AM
Gelcoat or Epoxy? blacktie Gear & Maintenance 19 03-18-2007 01:26 AM
polyester vs epoxy resin for underwater gelcoat efiedler Gear & Maintenance 1 04-09-2004 05:04 AM
