Old 01-31-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Cabin cushion material
What material do you think I should use for my cabin cushions? I'm thinking, they generally won't get wet (maybe). Cost is a consideration.
Old 01-31-2011
foam rubber is a good choice. look for a foam rubber distributor in your area to get a good price.
Old 01-31-2011
SanDiegoChip's Avatar
SanDiegoChip is on a distinguished road
foam densities
There are a lot of foam rubber densities out there. You can try sitting on them to see. We got some at Welcome to Keyston Bros for our bed until we decide what we want then we will get a mattress made.
As it turns out my side is super firm and for my wife’s side we cut two inches off the top (keyston bros shaved it off) then we added two inches of memory foam to her side. She likes it. That may well be how we have the mattress made but still not sure.
There are standard foam densities for cushions so you could start there.
Hope this helps,
Chip
Old 01-31-2011
centaursailor's Avatar
Senior in age only!!!
centaursailor is on a distinguished road
Am planning to replace my cabin cussions. Have been looking at the garden furniture section in local DIY and there are some ideal sized cushions in good colours for my main cabin. From what I can see this will work out a cheep as buying new foam. Won,t suit the v berth but I dont use it much and these cusions are in better nick anyway.
Happy sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
Old 01-31-2011
olson34 is on a distinguished road
Many it not most production boats, even high end, came with 1.8 density foam.
This goes flat when sat upon after about 2 or 3 years of normal use. Looks fine and the upholstery cover may well look like new... but the comfort goes away pretty quickly.
We re-foamed our factory upholstery with 2.6 density, in about 1995, and it still sits without "bottoming out" (pun alert...) and we sleep about 20+ nights on it a year without hip bones contacting the bunk tops.
So do check out the higher density. As to the numbers, our upholstery guy said those were pounds per cubic foot, IIRC.
BTW, the higher density costs a little more but not too much.
L
fastening to cabin fiberglass cabin interior marcusn Gear & Maintenance 3 09-06-2007 07:04 PM
Cabin cushion odor jjnks General Discussion (sailing related) 8 08-15-2007 10:13 PM
Under Cushion Material Ronbye General Discussion (sailing related) 16 06-29-2007 10:28 AM
cabin cushion replacement oday27 Gear & Maintenance 3 08-09-2006 05:24 PM
Cabin Cushion Covers -- Annapolis billkidd Gear & Maintenance 2 09-01-2002 04:03 AM
