02-01-2011
A small hand tire pump will work as long as it screws to the valve
make sure you open ( turn counterclockwise till they stop ) the 2 relief valves below the reservior, then fill with ( whatever ) fluid you choose to use till the full level or about 1/2" from the top of the sight glass. replace the fill csp and pump the system until the fluid is about 2" from the bottom or you have about 40lbs of pressure, then go bleed it at the AP
Repeat this until no air spits out at the AP; Once you reached that point, top off the canister and pressureize to 40-45lbs.
If the fluid level drops while doing the final top off, just release the air at the valve, fill and pressueize it again (40-45lbs)
Don't forget to the close relief valves when your done
Be glad you have a SV and not a PB, cuz you have to bleed all stations including the AP and that a PITA
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
