Air, Water or Air / Water Cooled Refer Condensor - Page 2 - SailNet Community
post #11 of 13 Old 02-02-2011
mitiempo's Avatar
Frigoboat seems to disagree. From their site:
Brian
mitiempo is offline
post #12 of 13 Old 02-02-2011
RichH's Avatar
Frigoboat doesnt much go past the 15 deg. 'approach' and it has HUGE surface area. BIG difference between the long run 'coil' of a Frigoboat and the small 2-3 ft. CuNi coil of a 'standard' system.
RichH is offline
post #13 of 13 Old 02-03-2011
Omatako's Avatar
Originally Posted by mitiempo View Post
If the water is 85 degrees wouldn't the air be a bit warmer, or at least as warm as that?
Yep, that's the truth.
In the tropics an ambient air temp of 35 degrees C is not uncommon and under those conditions it will negatively affect an air cooled unit. There is no doubt in my mind that a water-cooled condenser is the better way to go.
The only reason I never did that was because to get to an existing skin fitting from where the fridge installation is located was a total mission so I've opted for air-cooled. I may live to regret that choice.
Arthur C. Clarke
Omatako is offline
Water cooled air conditioners / water heaters graypenguin Gear & Maintenance 2 11-28-2010 02:40 PM
Why do we refer to wind and water movement differently? nolatom General Discussion (sailing related) 10 04-29-2010 12:09 AM
Raw water cooled issues and hot water davidpm Diesel 5 11-12-2009 05:11 PM
Raw water cooled issues? davidpm Diesel 5 11-10-2009 09:15 PM
Raw-Water-Cooled Engine Mark Matthews Gear and Maintenance Articles 0 12-26-2001 07:00 PM
