-   -   Air, Water or Air / Water Cooled Refer Condensor (http://www.sailnet.com/forums/gear-maintenance/71772-air-water-air-water-cooled-refer-condensor.html)
OceanFreedom 02-01-2011 06:44 PM
I would like to get the forumís thoughts on refrigerator compressors. Mine is a Water / Air cooled condenser and was wondering if I should replace it with another Water / Air or just Water only condenser. So far I have not found any information touting the benefits of one or the other.
We do plan on starting our world cruise in 5 years, spending most of our time in equatorial waters.
Any thoughts?
mitiempo 02-01-2011 07:05 PM
Water cooling is more efficient than air cooling. The warmer the climate the more important that it is water cooled.
olson34 02-01-2011 07:51 PM
The Frigoboat "keel cooler" heat transfer thru-hull is very efficient, especially in warmer climates where an air transfer system is weakest.
I installed one in our boat to keep the AH draw to a minimum. We like it a lot.
L
RichH 02-01-2011 08:27 PM
Depends on where you sail.
In the tropics, the ambient water is usually too warm (over 85 deg.) & water cooled is quite ineffective, energy wise. So, in the tropics you really more depend on air cooled then water-cooled adjunct.
To me, the best of all worlds is an air/water cooled, as when the water is too hot you simply turn off the pump and allow all the heat transfer by air cooling. Plus, when youre on the hard, turn off the pump and still have refrigeration.
All that stated, the 'best' is attained by 'monster' or Ultra-efficient insulation of the 'box', then your heat transfer and energy demand will be much much lower.
mitiempo 02-01-2011 10:25 PM
If the water is 85 degrees wouldn't the air be a bit warmer, or at least as warm as that?
nickmerc 02-01-2011 10:42 PM
Plus water can carry more energy than air. To back that up the manual on my AB cold plate suggests water cooling for warmer climates. Also, in the winter you will notice that if you run a humidifier, either whole house or in the room with the thermostat, the furnace will have longer off times.
I run mine on air cooling in cooler weather then turn on the water cooling in addition to the air when it gets warm.
________
GLASS PIPE
lancelot9898 02-02-2011 08:18 AM
Another factor to consider is the energy usage of that water pump not to mention the upkeep. Tarps over the boat should help keep the cabin to tolerable temperatures for the crew and that should provide a half way decent heat sink for the air cooled unit.
mitiempo 02-02-2011 10:31 AM
Frigoboat's water cooled system has no pump or moving parts. It is highly rated.
Frigoboat Home Page
nickmerc 02-02-2011 07:44 PM
When the temps rise and I turn on the water pump in addition to the air cooling my amp hours go down for the day vs using just air cooling.
________
Avandia Settlements
RichH 02-02-2011 09:01 PM
The heat transfer based on most refrig. Hx. is designed for a 15 F. degree 'approach' and are based on a maximum water inlet temp of 85 F. deg. (outlet @ 100 deg. F). Once you go beyond the 85įF inlet and exceed the 15į 'approach' the thermal transfer becomes VERY inefficient. ... and you need a Much larger than normal Hx and a Much higher flow of 'cooling' water to do the transfer. Simple heat transfer calculations and normal practices.
