Repair Cracked Teak Toe Rail - Page 2 - SailNet Community
post #11 of 16 Old 02-03-2011
Barquito
Barquito's Avatar
Similar problem
How about when the joint (half lap joint I guess) is separating?
Barquito is offline
post #12 of 16 Old 02-03-2011
BoatSmith
Boatsmith's Avatar
Clean it out as well as you can. A broken hacksaw blade can work well. Then clean it well with denatured alcohol , apply glue and clamp back together.
BoatSmith ---Boatbuilder
Boatsmith is offline
post #13 of 16 Old 02-03-2011
Sabreman's Avatar
I'd worry that such a short section would pull apart again without a screw to convince it to stay in place. Worth a try but if it happens again, I'd fair it and fill the gap with epoxy.
Sabre 38 "Victoria"
Sabreman is offline
post #14 of 16 Old 02-03-2011
RichH's Avatar
I fixed it for you.
I cut out the damaged wood and very carefully cut another scarf joint about 3:1 L/W ratio. I used a "Fein Multimaster' with very fine teeth on the blade to make the 'cuts, then 'shaved' the ends with a super sharp chisel so there would be no 'gaps'.
I replaced with entirely new wood, used recorcinol glue and then screwed it to the old, then bunged the countersunk screw holes.
Good as new.
It wont come apart as do 'glue only' repairs.
RichH is offline
post #15 of 16 Old 02-04-2011
Sabreman's Avatar
Nice fix.
Personally, I stay away from resorcinol since there are many more modern glues that do as good if not better than this classic glue. At one time, it was the only waterproof glue. Today we have Titebond III and epoxy's that are awesome.
Sabre 38 "Victoria"
Sabreman is offline
post #16 of 16 Old 02-04-2011
RichH's Avatar
Disagree ... for me nothing beats Recorcinol as the adhesion and doesnt lose its bond when the wood becomes saturated. Its still 'the glue' used in the manufacture of marine plywood.
RichH is offline
Help removing teak toe rail saladpe Gear & Maintenance 10 11-01-2010 06:35 PM
Teak toe rail repair drlove Gear & Maintenance 1 08-26-2009 06:25 PM
repairing teak rub rail LookingForCruiser General Discussion (sailing related) 3 04-01-2009 04:20 PM
teak rub rail adamlaw Gear & Maintenance 2 12-30-2007 10:32 PM
plexiglass cracked dome repair anadem Gear & Maintenance 7 10-27-2007 10:54 AM
