02-02-2011
The only issue with what Sabreman says, is that most epoxies are not very UV-tolerant. You could certainly use another waterproof, uv-tolerant glue to make up a putty to fill the voids/cracks.
Good boat btw, IIRC, it's the same as Ella's Pink Lady, that Jessica Watson used to solo circumnavigate last year.
