02-06-2011
First of all, a lot depends on how you have your boat's sail plan balanced. If it isn't properly balanced, the tillerpilot is going to have difficulty steering the boat, whether to a compass course or to the apparent wind.
Another factor will be how well you have the wind instrument calibrated.
A third factor will be how high you have the gain and compensation on the tiller pilot set.
A fourth factor is how much of a tendency your boat has to follow a straight course. If you said what boat you're on, it would help a lot. An older, full-keel design may have fewer issues that a high-aspect ratio bulb keel modern racing design when trying to sail to apparent wind on a tillerpilot.
Generally, as a rule, the more specific and relevant information you give when asking a question, the better the quality of the answers you will get.
