LED vs incandescent Nav lights - Page 4 - SailNet Community
post #31 of 47 Old 02-07-2011
Originally Posted by prroots View Post
With all this talk about certification, what is the situation when you put a replacement incandescent bulb into an incandescent fixture that is made by a different manufacturer (eg, Ancor bulb in Aqua Signal fixture). Is that the same problem as when placing an LED bulb into an incandescent fixture?
Pete
If the bulbs meet the same specification in terms of wattage and such, I doubt that it would be much of an issue. A LED bulb doesn't meet the same specifications as an incandescent bulb it is replacing--in terms of color, angle of coverage, brightness, etc. In one, you're replacing apples with apples and in the other you're replacing apples with kiwi fruit.
sailingdog is offline
post #32 of 47 Old 02-07-2011 Thread Starter
Beneteau 411
All true, but it was never certified with a 3rd party bulb so technically the same issue would seem to remain? For example, I think West Marine is offering Ancor bulbs for replacement in Aqua Signal fixtures. I realize I'm being nitpicky, but mostly wanted to make the point that one can only go so far with this certification business.
pete
prroots is offline
post #33 of 47 Old 02-07-2011
Yes, but it is also far more likely that you'll be challenged in the case of an accident using non-certified LED BULB/FIXTURE combos than if you were using a different brand of incandescent bulbs.
pete
post #34 of 47 Old 02-07-2011
Would the term sea lawyer apply here?
The regulations are pretty clear on what is required from the lights and my concerns would be with older boats with hazed lenses and corrosion. Certified lights simply mean that the lights have been tested to be visible at the range, colors and angles noted in the regulations.
Catalina 36 MKII
Florida
HeartsContent is offline
post #35 of 47 Old 02-07-2011
Having uncertified fixtures becomes an issue of liability if you are involved in a collision at night. Even if you were not at fault, if you were found to have uncertified nav lights, you can be found liable, and that can affect whether the person is at fault skates or not.
post #36 of 47 Old 02-08-2011 Thread Starter
Beneteau 411
I've decided to replace my series 41 Aqua Signal fixtures as needed and install the Ancor incandescent bulbs from West Marine. The combination may not be certified, but given West's position in the marketplace it would be hard to fault that path. Additionally we'll start saving (and rationalizing) the purchase of a LED combo tr-color/anchor light for the masthead. I would appreciate recommendations on the tri-color/anchor lights. I have seen them from 4 different manufacturers.
Pete
prroots is offline
post #37 of 47 Old 02-08-2011
Pete
I'd recommend the OGM tri-anchor, because it can be wired using just two wires, so you may be able to avoid running new wires down the mast.
post #38 of 47 Old 02-08-2011
Argyle38's Avatar
Originally Posted by mitiempo View Post
Argyle38
I don't believe manufacturers have their installation certified by the CG. Nor do I believe the CG even does that on recreational boats. They purchase the fixtures and install them, hopefully properly. The CG only certify the fixture/bulb combinations.
Interesting. I thought that maybe UL or someone similar might be contracted to verify adherence to the USCG rules. I would be willing to bet that European built boats must test to meet some CE/EU requirements. It would not surprise me at all if TUV had a marine division. It would take some specialized equipment, but nothing too outrageous.
S/V Argyle
Downeaster 38 #40
Argyle38 is offline
post #39 of 47 Old 02-08-2011
Actually, if you've read the USCG specifications, you'd realize that it would take some fairly sophisticated equipment to test the nav lights for certification. It isn't as simple as whether they are visible at a given distance...it has a lot to do with the cutoff angles of the sector, the color of the light, etc.
post #40 of 47 Old 02-08-2011 Thread Starter
Beneteau 411
Thanks for the recommendation. I must say their website leaves a lot to be desired. Under the news heading, the latest is 6 years old. When you click on other links, it reports 'fatal error'. Wonder what their problem is? If I didn't know better, I'd say they are bankrupt or going out of business? If they were a profitable, up and coming company you would think they could keep their website up to date. Maybe the LED business is suffering.
I briefly compared the OGM site to the Signal Mate site. The Signal mate draws less current (.3 vs .5 Amps), offers a 5 year vs 2 year warranty and cost $60-70 less. It is available in 2 or 3 wire version. I wonder why that wouldn't be the best choice?
Pete
prroots is offline
LEDs vs. incandescent Spoonman Electrical Systems 18 12-01-2010 06:15 AM
Incandescent to LED hulagirla Electrical Systems 7 01-24-2010 07:12 PM
Lights bacampbe General Discussion (sailing related) 3 07-15-2009 08:30 PM
Identification Lights & Nav Lights on Sailing Vessels Boasun General Discussion (sailing related) 10 02-13-2009 09:42 AM
