LED vs incandescent Nav lights
Most all of our Nav lights on our new-to-us 2001 Beneteau 411 required replacement of fixture due to extensive corrosion or at least clean up with new bulb. We're wondering if this is the time to switch to LED? The Nav lights are the series 41 from Aqua Signal. The bulb style seems to be a BAY15D with Index (offset side pins). I know there have been similar posts before, but would like to learn the trade-offs between LED and incandescent with actual numbers eg, lifetime, current draw, etc. My preference would be to stick with the current series 41 fixtures given mounting and electrical wiring considerations and if it makes sense switch to an LED bulb that is compatible.
Here is West Marine's offering of LED Nav lights: DR. LED Bulb-led at West Marine and here is Dr LED's cross reference table: http://www.doctorled.com/crossref.htm What I don't understand yet, is what you do in, for example, the case of the bow light. My Aqua Signal series 41 uses a red/green lens to convert a white bulb to the appropriate color. When switching to LED do you put their white bulb in or do you use their red/green bulb and perhaps change the lens to clear? Pete |
We 'bit the bullet' and just changed to sealed LED fixtures. No failures in between 2 and 3 yrs.
Well worth the cost especially the masthead tricolor which has been untouched for 3 yrs...worth the money to keep me going up a 76ft stick. Phil |
1 Attachment(s)
I have heard conflicting information on this. Dr LED's statement is below. My local marine store (not West Marine) says the opposite - and they are a Dr LED dealer.
I would guess if you are going to change the lens you might as well buy a whole new light. As far as consumption, the replacement bulb for your 41 bi-color (Dr LED Polar Star 41) uses .09 amps. If you currently have a 25 watt bulb you are consuming 2 amps. Everything I have seen says over 50.000 hours or more but there is no guarantee on that. |
Pete |
Pete |
I would replace the incandescent anchor light fixture with an LED tri-anchor fixture. I know that with the OGM tri-anchor, you can use a special switch and get away without needing to replace or add any new wire to the mast -- they reverse the polarity to between tri-color and anchor. Don't know if the LopoLight or other makers have a similar feature.
Out in the big blue water I like my very high and visible tricolor which inculdes an anchor light and a strobe for emergencies and we used the original cable.
Orca Green Marine Technology - LED Lighting In anchorages the high anchor light does get lost when you are close to the boat (our stick is 76 ft) so we also have LED spreader lights the illuminate the boat itself. |
Pete |
LED Nav Light
On our 1998 Bene 352 we replaced the bi-color bow light bulb (in an Aqua Signal 41 fixture) with a Dr. LED bi-color LED "bulb". You need to use a bi-color LED "bulb" not a clear one, even though the old incandescent was clear white. The results have been as good or better than the old bulb with 1/10 the current draw. You can use a clear white LED for the stern light. Next project is to replace the anchor light with an LED.
Pete |
| All times are GMT -4. The time now is 07:32 PM. |
SEO by vBSEO 3.6.1
