Help choosing my barrier coat system: Interprotect vs. West System vs. Other? - Page 2 - SailNet Community
post #11 of 31 Old 02-08-2011
dougshipl's Avatar
We're in the warm waters of FL and have been using Trinidad SR over our 2000e for years. No issues, and as noted prep and application is everything. With that said, a few years back we had an Irwin we sailed in San Francisco area and an ol salt recommended a commercial barrier product from Ameron. Its was used on the mega yachts at the time. It was less then $40 a gallon and went on almost like tar...then we followed up with Trinidad. He was right, it was cheap, thick and I don't think anything would ever get through it. It worked fine, no blisters, etc for years. I note this in event someone is on a tight budget and doesn't want to over pay for the hyped up marketing on traditional boat store products. But like I said, we've had no probs with the 2000 with Trindad SR.....except the $
dougshipl is offline
post #12 of 31 Old 02-08-2011
Its not a decision its a choice..
The Incredible Hull: Barrier Coat
have fun!!!
gtod25 is offline
post #13 of 31 Old 02-09-2011 Thread Starter
Sailing to surf
Beersmith's Avatar
Some people claim that 2000E has problems with "Orange peeling", which I have seen on boats around the yard. Does that significantly effect performance at all? My boat is a heavy displacement cutter, so I'm not terribly worried about performance, but if I loose a half knot I wouldn't be happy.
My boat rebuild/sailing blog:
Beersmith is offline
post #14 of 31 Old 02-09-2011
T37Chef's Avatar
If you use Interprotect 2000E, you can alternate the colors to make sure you get the proper coverage levels
Last I looked, you can do the same with the Pettit product as well, I think white & grey are available?
Shawn
T37Chef is offline
post #15 of 31 Old 02-09-2011
I doubt the barrier coat would affect your boat speed at all, especially given that you're a heavy displacement cutter design.
sailingdog is offline
post #16 of 31 Old 02-09-2011
He was discussing west systems vs. Interprotect... Pettit wasn't even a contender... read his post.
post #17 of 31 Old 02-09-2011
T37Chef's Avatar
Originally Posted by Beersmith View Post
well after reading this I'm still torn between West System (using 422 Barrier coat additive) or Interprotect 2000E.
Any other arguments for one or the other?
The Pettit & Interlux barrier products are pretty much the same I think so I would probably just go with the less expensive one. The link I provided above I am using Pettit and found it to be easy to work with and has held up fine since application a few years ago now.
Shawn
T37Chef is offline
post #18 of 31 Old 02-09-2011
T37Chef's Avatar
I get that I was clarifying there is another option besides Interlux Interprotect!!!!!!!!!!!!!!!!!
Shawn
T37Chef is offline
post #19 of 31 Old 02-09-2011
T37Chef's Avatar
Sailingdog...In fact you yourself say something very similar here: Barrier Coat Petit vs Interlux
Shawn
T37Chef is offline
post #20 of 31 Old 02-09-2011
and I was just busting your chops.
Tips for barrier coating with Interprotect? mrybas Gear & Maintenance 4 08-20-2010 11:45 AM
West System SIX10 kwaltersmi Gear & Maintenance 1 03-18-2010 02:58 PM
West System Pumps. Suberk Gear & Maintenance 9 03-03-2009 12:28 PM
Curious about the West Epoxy System BigAssHam Sailboat Design and Construction 14 11-22-2007 10:48 PM
WEST SYSTEM Boys Bilge_Scum General Discussion (sailing related) 0 07-07-2001 05:30 AM
