Help choosing my barrier coat system: Interprotect vs. West System vs. Other? - Page 3 - SailNet Community
post #21 of 31 Old 02-09-2011
T37Chef's Avatar
Don't have time to read them myself, but here:
http://www.pettitpaint.com/fileshare...ds/1470122.pdf
http://www.yachtpaint.com/MPYACMData...Y+20100614.pdf
Shawn
T37Chef is offline
post #22 of 31 Old 02-09-2011 Thread Starter
Sailing to surf
Beersmith's Avatar
Originally Posted by T37Chef View Post
thanks
My boat rebuild/sailing blog:
Beersmith is offline
post #23 of 31 Old 02-09-2011
I don't discuss my member
zz4gta's Avatar
There will be a difference in performance between a smooth bottom and one w/ orange peel. Not a big difference, but there will be one. Just put on an extra coat of barrier, and then sand it with 80 or 120 before the bottom paint. Should knock down any lumpiness and make for a pretty smooth finish.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #24 of 31 Old 02-09-2011
ASA and PSIA Instructor
If you are going to sand the faired areas or the bottom in total for smoothness, be sure to use a long board, see 3m Longboard, as that's the only way to remove the high points. You also need to use a long board if you actually shape your foils, which is pretty unusual outside of one-design racing.
This is an ugly and painful job best done by teenagers.
sailingfool is offline
post #25 of 31 Old 02-09-2011
RichH's Avatar
No need to sand a 'new' barrier coat to make it smooth.
You can apply the first coat with a roller but successive coats with a large polyethylene trowel (not a roller) and 'fill' the previous hills and valleys from the roller application. Method: roll on and immediately 'wipe' with a trowel, the semi-hard 'peaks' from the first 'roller coat' will set the height for the trowel to 'glide' on --- thus quickly filling and fairing the 'valleys'. This 'troweling' is in the same manner as applying the final gelcoat to a MALE plug mold. For perfectly smooth and faired you can finish with a thinned out fairing coat using a BIG trowel.... and the WHOLE job should be continuous so that NO layer 'fully cures' so that there is continuous bonding throughout. This can include the first bottom paint coats (hot-coating) for much better 'adhesion'.
The MOST IMPORTANT characteristic or goal of ANY barrier coat system is the MIL-THICKNESS. Without the proper mil-thickness you are vulnerable to future water (principally water vapor) permeation through the barrier coat into the FRG. With a roller you have to apply MORE barrier so that the deepest 'valley' is at the proper thickness; with a smooth or troweled-on application that required thickness is more easily controlled.
How to know that you have the proper thickness --- go to an industrial paint/coating supply and get 'mil-thickness gages'. These are 'little comb-like or 'toothed' gages' that you 'push' into the fresh/wet paint or coating and if you get discontinuous dots or dashes in the fresh surface instead of lines the thickness is too small and you need to add more paint/coating. With solvent based coatings you need to calculate the % solids so that when the solvents 'flash off' and the coating 'shrinks' you ultimately arrive at the recommended 'dry' mil thickness not the 'wet' / 'as applied' mil thickness.
Each barrier coating mfg. lists the proper 'thickness' in their 'tech manuals'. If you dont apply to the recommended (dry) mil thickness, you can expect to not have sufficient barrier applied and you will/may/can after some time observe the 'return' of the blisters/pimples. I always apply more thickness than what the mfg. recommends as I dont want to do a job 'twice' ... and barrier coating manufacturers seem to always continually 'increase' their thickness recommendations over time.
hope this helps.
RichH is offline
post #26 of 31 Old 02-09-2011 Thread Starter
Sailing to surf
Beersmith's Avatar
Thanks for this information. I am curious about the trowelling method, it seems that trowelling on successive layers would be considerably thinner than if applied by roller. Am I just overthinking it?
You can apply the first coat with a roller but successive coats with a large polyethylene trowel (not a roller) and 'fill' the previous hills and valleys from the roller application. Method: roll on and immediately 'wipe' with a trowel, the semi-hard 'peaks' from the first 'roller coat' will set the height for the trowel to 'glide' on --- thus quickly filling and fairing the 'valleys'. This 'troweling' is in the same manner as applying the final gelcoat to a MALE plug mold. For perfectly smooth you can finish with a thinned out fairing coat .... and the WHOLE job should be continuous so that NO layer 'fully cures' so that there is continuous bonding throughout. This can include the first bottom paint coats (hot-coating) for much better 'adhesion'.
How to know that you have the proper thickness --- go to an industrial paint supply and get 'mil-thickness gages'. These are 'little comb-like or 'toothed' gages' that you 'push' into the fresh/wet paint or coating and if you get discontinuous dots or dashes in the fresh surface instead of lines the thickness is too small and you need to add more paint/coating. With solvent based coatings you need to calculate the % solids so that when the solvents 'flash off' you ultimately arrive at the recommended 'dry' mil thickness not the 'wet' / 'as applied' mil thickness.
hope this helps.
post #27 of 31 Old 02-09-2011
RichH's Avatar
No, the peaks and pimple-tops from the previous 'roll coat' set the depth, the trowel 'rides' on top of the previous peaks. Usually takes 2-3 trowel applications to get the barrier smooth. You dont want to knock-down the first/previous 'pimples' with a trowel as they set the height for the trowel to fill. If you find that youre not 'thick enough' add another 'roll coat' and let partly cure.
You can apply bottom paint in the same way ... and you get a smoothness equivalent to 'almost as smooth as a babies ass'. Smooth surfaces have less adhesion for 'growth' ... and 'release' faster and more completely when at speed - less 'roughness' for the crap to 'stick to'. With smooth applied ablatives you also get longer life as the 'total' surface area exposed is at a minimum - somewhat important if you seen the latest prices for ablatives.
RichH is offline
post #28 of 31 Old 02-09-2011
engele's Avatar
Could not be more true
I can verify the truth of this. After spending many many hours with a longboard I passed the hat (and the respirator) to a broke teen in need of work, and it was the best spent $200 I have ever made (our agreement was for $100, but I couldn't do it when payday came. We were both happy).
engele is offline
post #29 of 31 Old 02-09-2011 Thread Starter
Sailing to surf
Beersmith's Avatar
West System describes applying the barrier coat using a roller, then tipping off with a piece of cut up roller to smooth out the application. Would this method work just as well with Interlux, Pettit, or whatever product I use? Or even tipping off with a brush to avoid the orange peel?
Such as described here: Barrier Coating
post #30 of 31 Old 02-09-2011
I don't see why it shouldn't.
sailingdog is offline
Tips for barrier coating with Interprotect? mrybas Gear & Maintenance 4 08-20-2010 11:45 AM
West System SIX10 kwaltersmi Gear & Maintenance 1 03-18-2010 02:58 PM
West System Pumps. Suberk Gear & Maintenance 9 03-03-2009 12:28 PM
Curious about the West Epoxy System BigAssHam Sailboat Design and Construction 14 11-22-2007 10:48 PM
WEST SYSTEM Boys Bilge_Scum General Discussion (sailing related) 0 07-07-2001 05:30 AM
