Help choosing my barrier coat system: Interprotect vs. West System vs. Other? - Page 4 - SailNet Community
post #31 of 31 Old 02-09-2011
RichH's Avatar
Originally Posted by Beersmith View Post
West System describes applying the barrier coat using a roller, then tipping off with a piece of cut up roller to smooth out the application. Would this method work just as well with Interlux, Pettit, or whatever product I use? Or even tipping off with a brush to avoid the orange peel?
Such as described here: Barrier Coating
The hotter the day and the hotter the hull, the less chance of 'flow out' when dragging a cut roller; and, if youre 'late' or delayed in tipping out you can get 'tears', etc. in the surface. So, if youre going to use the 'tip with roller' method, you cant do this on the whole hull side and the barrier will start to 'kick' before you are finished tipping when its 'warm' outside.
The polyethylene trowel 'forces' the flow-out.
RichH is offline
Tips for barrier coating with Interprotect? mrybas Gear & Maintenance 4 08-20-2010 11:45 AM
West System SIX10 kwaltersmi Gear & Maintenance 1 03-18-2010 02:58 PM
West System Pumps. Suberk Gear & Maintenance 9 03-03-2009 12:28 PM
Curious about the West Epoxy System BigAssHam Sailboat Design and Construction 14 11-22-2007 10:48 PM
WEST SYSTEM Boys Bilge_Scum General Discussion (sailing related) 0 07-07-2001 05:30 AM
