Mechanical difference between roller furling and reefing? - SailNet Community
Blogs
Old 06-09-2003
duffer1960's Avatar
Catalina 38 Avantura
duffer1960 is on a distinguished road
What is the mechanical difference between a roller furling and a roller reefing headsail system? I know roller furling only lets you run with the sail all the way out or fully furled, whereas roller reefing lets you reef the headsail to different percentages. Is the difference only in the foil (stronger), or is there something else? Also, can a roller furling system be converted to a roller reefing system?
Thanks.
Russ
Old 06-09-2003
Sailmc is on a distinguished road
I believe all the systems today both reef and furl. The only time you see a system used only to furl is when someone is furling a mylar sail. These really can''t be used in a reefed posistion without causing damage to the sail.
Old 06-09-2003
maxcontax is on a distinguished road
On my little boats, furling gear had a swivel at the head of the jib, attached to a wire cable along the luff edge to a furling line at the tack: if you partially furl (reef) with this, the load on the sail will torque the luff edge wire and the sail will unfurl. Roller Reefing has a solid bar along the luff edge that will not twist under load, allowing for partial jib sail plans. Mechanically, that was the difference.
Old 06-09-2003
geohan is on a distinguished road
The difference between roller furling and roller reefing/furling is primarily in the construction of the sail to prevent excessive draft when reefed. My Norlam genoa (dacron/mylar/dacron sandwich) has a piece of 3/4" thick soft foam incorporated in the luff. It is about 12" wide at midheight, tappering to about 2" at each end. Its purpose is to roll up the center of the sail around a larger diameter thus flattening the sail. There are also patch reenforcements on the leach and foot at selected reefing positions.
Old 06-09-2003
knothead's Avatar
You should be able to reef with any furling system that has the extrusions covering the headstay. Without the foam luff you may not get a real good shape but that has never been a real issue with me. I''m usually just trying to reduce sail in a hurry.
Some furling systems incorporate a tack swivel which allows the belly of the sail to start rolling up before the foot and that is also said to give a better shape.
But as was mentioned earlier, if your system is consists of only the furling drum at the bottom, a swivel at the top and the sail has a wire luff, then it was made for furling only.
Old 10-26-2009
jbzeichner is on a distinguished road
To those with NorLam genoas, have you been satisfied? How is the sail olding it's shape over time? I've heard mylar sails shrink and the leech will cup and that they can have mold problems.
Thanks,
Brian
Old 10-26-2009
midlifesailor is on a distinguished road
Continuous line systems like the POS Hood system on my boat for the genoa, are designed to furl the sail without capabilty to reef.
There are some but high quality continous line units designed for large light air sails (in addtion to a furler/reef system for the genoa)that are also not intended to reef the sail only to furl.
s/v Palmetto Moon
1991 Catalina 36
anxiety in buying a boat casey1004 Boat Review and Purchase Forum 35 10-29-2003 07:09 AM
Roller furling main locks when reefing RFranco Gear & Maintenance 1 02-12-2003 07:11 AM
Jib Furling Systems - Results robrichtx Gear & Maintenance 0 12-15-2001 11:21 AM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
