Old 02-08-2011
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
Alternative Spectra Pickling Agent ?
HELP I need to pickle my Spectra 150 watermaker for 4 weeks and can not find the SC1 pickling agent in Guadeloupe or Antigua and I have left it too late to get some sent here.
Is there any readily available alternative substance that I can use.
Old 02-08-2011
hellosailor's Avatar
The MSDS information on Spectra's web site indicates that the pickling chemicals are "OSHA PEL ACGIH TLV" which they refer to as a proprietary formulation of common chemicals, sometimes with Boric Acid which is often used as a buffer.
I'd suggest calling Spectra, telling them you are between a rock and a hard place, is there something you can get locally that will be better than nothing for a month. Some folks suggest sodium metabisulphite, which is commonly used as a biocide in home brewing equipment and fairly innocuous, but why not ask Spectra directly?
Old 02-08-2011
lshick is on a distinguished road
Send a message via Skype™ to lshick
I believe they support the use of non-toxic antifreeze as an alternative agent. From my 200C manual: "Flush 5 gallons of potable water system antifreeze straight through the system instead of using the normal SC-1 storage procedures. The antifreeze will prevent biological growth as well as freeze protection."
Larry Shick
V42-148 "Moira"
Old 02-08-2011
"non-toxic antifreeze"
Wodka!
As long as the plastics don't mind that.
Old 02-08-2011
erps's Avatar
the pointy end is the bow
I talked to a fellow from AquaMarine? at the Seattle boat show last month and had some follow up conversations with him via email and one of the questions I had was about pickling the membrane. IIRC, he mentioned if you flushed the membrane with product water monthly, you don't have to pickle it. Does anyone practice that?
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 02-08-2011
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
Panic over as I found a supplier of the Spectra agent. Mind you it is $30 a shot!
I did note the use of the glycol based antifreeze but you get funny looks in Antigua if you ask for antifreeze.
spectra and sta-set for spin sheet davidpm Gear & Maintenance 8 08-15-2009 09:01 AM
Spectra for Swing Keel Pennant? tager Gear & Maintenance 7 01-16-2009 01:48 PM
Pickling A Gas Tank CellNav Gear & Maintenance 6 08-20-2008 08:45 PM
Spectra Backstays Zogumwesterly Gear & Maintenance 6 08-04-2007 10:37 PM
Spectra Lifelines? rrobar Gear & Maintenance 5 03-01-2002 07:17 AM
