Cheap boom replacement ideas for small sailboat? - Page 2 - SailNet Community
 1Likes
post #11 of 17 Old 02-11-2011
Another option is to find a boom off another boat used and cheep. A laser mast could be retrofitted, perhaps a hobie mast or boom. Look for a bombed out hull in the local club (ours cut up a few last year with a chainsaw) and see if they will part with the spars for less.
baboon is offline
post #12 of 17 Old 02-11-2011
RichH's Avatar
Originally Posted by PeterSailer View Post
I think the cheapest way would be to go with wood again, and take all your hardware from your old boom. Thats what I would do. Pretty simple too
Precisely !!!!!! find a lumber yard who deals in PRIME GRADE wood 2x4's, select a straight grain, 'clear' - with NO knots - 2x4X12 ft. long. - go through the 'pile' and choose only perfectly STRAIGHT wood and 'clear' with NO KNOTS - eyeball it on all '4 corners' for straightness.
The foot length dimension of a M16 main is 10,33 ft., the MC is 11 ft. .... so a 12ft. CLEAR GRAIN fir or hem-fir 2x4x12 ft. (about $8.00+ for 'clear grain' , no KNOTS) would be your cheapest way.
BTW - You're NOT going to find PRIME Grade 2x4x12 ft. in a Home Depot or Lowes or other 'big box' stores.
No need to bore-in a boltrope track, just fly the mainsail 'loose footed' - no track slugs, no boom track. Carefully PRIME + OIL BASED enamel, etc. (many coats) to retard moisture uptake to prevent warping, etc. Use all the hardware you already have on the rotted boom ... just carefully 'bed it in' to the new 2x4
capta likes this.
RichH is offline
post #13 of 17 Old 02-11-2011
RichH's Avatar
Precisely !!!!!! find a lumber yard who deals in PRIME GRADE wood 2x4's, select a straight grain, 'clear - with NO knots - 2x4X12 ft. long. - go through the 'pile' and choose only perfectly STRAIGHT wood and 'clear' with NO KNOTS - eyeball it on all '4 corners' for straightness.
No need to bore-in a boltrope track, just fly the mainsail 'loose footed' - no track slugs, no boom track. Carefully PRIME + OIL BASED enamel, etc. ...(many coats, especially covering the 'end grain' at the butt ends to retard moisture uptake to prevent warping, etc. Use all the hardware you already have on the rotted boom ... just carefully 'bed it in' to the new 2x4
RichH is offline
post #14 of 17 Old 02-11-2011
Old Gaffer
FishSticks's Avatar
You specified the cheapest. Many thousands of small working sailboats go to sea with a sapling for a boom.
Never sail closer to the wind in degrees than your age
FishSticks is offline
post #15 of 17 Old 02-11-2011
Senior in age only!!!
centaursailor's Avatar
Thumbs up
Originally Posted by tommays View Post
I would price out a piece of Aluminum Tube before going with the PVC as its pretty flexible even in #80 and will be hard to fasten stuff to it compare to Aluminum as you should be able to get a hunk for about 60 bucks
Reckon this could be the best and possibly cheapest answer. You have all the hardware already.
Just can,t see the plastic having the rigidity over 10ft length when the wind blows and you need to harden up the foot.
Look around the local machine shops or scrap yards. Never know what you might find. Theres all sorts of extrusions in use and the shape isn,t as important as strength.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
post #16 of 17 Old 09-19-2016
Re: Cheap boom replacement ideas for small sailboat?
Using the aluminum tube inside Fiskars tree pruner. Took cutting blade and chain off, mounted to piece of epay wood then u-bolted to 2" Bic Melody mast. Bic sail replaces giant sail that comes with my Force 5 So I can get under railroad bridge and the raise entire rig while on the water. 16 foot Bic mast is fiberglass and being for a wind sailer is easily lifted. Cutting head has a 160 degree adjustment with lock off. This will replace the vang. Flat nylon cord is the out haul using the included roller at the outer tip. 2 chrome tie downs riveted along with 16 inch by 1 aluminum strip that hold the harken rollers for the main sheet. Might add a real vang if lock off doesn't hold. Weight about 1 lb.
Bug1000000000 is offline
post #17 of 17 Old 09-20-2016
TQA
Bombay Explorer 44
TQA's Avatar
As this is a five year old thread I guess the OP has fixed it by now.
TQA is offline
Bimini replacement ideas and opinions lans0012 Gear & Maintenance 25 08-03-2010 03:48 PM
Cheap boom gallows Survivor Gear & Maintenance 4 06-27-2010 08:45 PM
Whats small, fast, weatherly and cheap? HUGHM Boat Review and Purchase Forum 18 05-26-2009 10:21 AM
Need a very small, very cheap, sailing dinghy beej67 Boat Review and Purchase Forum 3 08-05-2008 01:41 PM
replacement boom oldquahoger Gear & Maintenance 7 03-05-2008 08:25 PM
