Chainplates - Page 2 - SailNet Community
 4Likes
post #11 of 25 Old 02-12-2011
The stock you buy is not smooth at all, and to get a mirror finish is extremely time consuming so we had that done at a shop as well ($350).
By rights, you should get them polished and electroplated if you want to do it right....
sidmon is offline
post #12 of 25 Old 02-12-2011
mitiempo's Avatar
Or you could use bronze.
Brian
mitiempo is offline
post #13 of 25 Old 02-12-2011
chainplates
I have just made new chainplates for my Formos 41. I have access to polished SS and can give you a price for making the same for you, if you are interested.
dfreer is offline
post #14 of 25 Old 02-12-2011
Actually, you want the polished to a mirror-like finish and the ELECTROPOLISHED to smooth the surfaces at a microscopic level... you do not want them ELECTROPLATED.
sailingdog is offline
post #15 of 25 Old 04-06-2012
Re: Chainplates
is the polishing just for aesthetics ?
gdecon is offline
post #16 of 25 Old 04-06-2012
Chastened
Ajax_MD's Avatar
Re: Chainplates
No, it's to achieve a totally smooth surface with no microscopic crevices that will allow crevice corrosion to take hold.
Stainless steel does not rust on the surfaces exposed to oxygen, but they do corrode and fail in an anaerobic environment, which is usually the part of the chainplate that is encased in the deck.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #17 of 25 Old 04-06-2012
The Witchdoctor
Re: Chainplates
I had the same problem with my Hudson Force 50. I had pulled the chain plates and had them repaired. They welded another thick piece of stainless over the crack and extened the repair so that at least one bolt was also included in the repair area. It works fine.
medicrene is offline
post #18 of 25 Old 04-06-2012
Senior Moment Member
SloopJonB's Avatar
Re: Chainplates
Polishing is not the same as ELECTROpolishing. The former merely makes the metal shiny and pretty. The latter is an electrical acid bath process that removes the iron molecules from a thin layer of the surface. This gives corrosion no place to start.
If you want nice, shiny AND corrosion proof chains, first get them cut, drilled & ground to final shape. Next, sand them and polish/buff with a wheel polisher. When they look like you want them, have them electropolished. When you get them back they will no longer have the perfect, shiny finish but a SMALL amount of buffing will bring it back.
You have to be careful with this last step as the protective layer is apparently only .001" to .0015" so you can buff right through it if you go to heavy on the final buffing.
I did mine this way years ago and they still look like they were just buffed.
SloopJonB is offline
post #19 of 25 Old 04-06-2012
SloopJonB's Avatar
Re: Chainplates
Is it worth risking your rig, deck, crew and most importantly SELF, just to save the few extra bucks new chains would have cost you? It isn't that expensive to make new ones up. I would think it would be less than merely painting the bottom of that monster (just how many acres of wetted surface DO those boats have?).
mitiempo and StormBay like this.
post #20 of 25 Old 04-07-2012
Cruiser2B's Avatar
Re: Chainplates
i know this is an older thread but people may still be researching doing their own chainplates. i replaced all 8 of mine on my Alberg 30 this winter. i used 316ss and made them out of larger stock than factory units. Total cost was $80.00. that price included all the material. i was able to make all 8 from a 6ft piece of 1.5"x6'ft piece. obviously it would have cost more if i had someone else do it but i enjoyed the experience. i only polished mine...no plating. the factory 304 units lasted 40yrs so i figure my new much thicker and wider units should last me quite a while!
svsalacia.blogspot.com
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
Chainplates tager Gear & Maintenance 3 04-17-2009 12:53 PM
My Chainplates simple72 Gear & Maintenance 13 11-11-2006 07:19 PM
Pearson10M chainplates duke Gear & Maintenance 10 09-11-2006 10:04 PM
chainplates mary jewell Gear & Maintenance 1 10-25-2002 06:10 PM
