Soliciting sage haulout advice - Page 2 - SailNet Community
post #11 of 16 Old 02-15-2011 Thread Starter
Ten four. I'll check out what they like at the yard for the packing. It's two and a half hours away, but we're still a month ahead of schedule. I should get a look tonight. As far as the blisters go, the photos look good, the few open blisters have gel coat underneath, there was a spot that will need epoxy from a crab pot strike, and I'm told the rudder is in good shape. They will start the bottom paint next week, and we are expecting Spring weather.
Willy-Nilly
1984 Endeavour 33 sloop
Albemarle Sound
willynilly is offline
post #12 of 16 Old 02-15-2011 Thread Starter
Trying to post an image, but we have trouble getting AM radio out here, much less a fast connection!
Willy-Nilly
Albemarle Sound
post #13 of 16 Old 02-15-2011
souljour2000's Avatar
I would suggest letting it dry out for a month under a tarp ...and meanwhilst attend to other smaller projects...then let them do the bottom job...(if you can afford the extra month)...
The paint and barrier coat will stick and absorb much better at that point IMHO...
I am getting ready to haul out my Seafarer 24 and plan on 4-6 weeks drying time before I do any painting but she's a fairly ancient hull from 1971 and I want to insure good adhesion since the bottom paint on her from her '05 bottom job by earlier owner now is literally peeling off in fairly large strips. Good luck
souljour2000 is offline
post #14 of 16 Old 02-15-2011 Thread Starter
Thanks, SJ2K. The yard will take it's time, doing the bronze, zinc, and through hull work first. Should be a few weeks before they start the sanding and prep. Meanwile, I'll prep the deck and brightwork for paint and varnish, and a new dodger will be the cherry atop the dessert!
Willy-Nilly
Albemarle Sound
post #15 of 16 Old 02-15-2011
blt2ski's Avatar
Something I will do on the next haul out, altho a good diver can do this. If you have a max prop or equal, and want/need to change out the pitch, this is a good time, or for that matter, change from a fixed to a folding/feathering prop for a bit more lighter air performance. I' going to add one pitch adjustment to my max prop to see if I can get a bit more speed out of the boat.
Otherwise, lots of good advise to chew over!
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #16 of 16 Old 02-15-2011
ASA and PSIA Instructor
After cleaning the prop and shaft, paint both with 3-4 coats of this stuff http://www.pettitpaint.com/fileshare...ds/1179320.pdf
and they will stay barnucle free for at least six months or more, depending on local conditions.
sailingfool is offline
Haulout - Advice needed KeelHaulin Gear & Maintenance 5 11-17-2009 03:41 PM
Soliciting opinions regarding my next boat ajf10 Boat Review and Purchase Forum 13 10-27-2008 05:49 PM
Soliciting Thoughts on NMEA 2000 MikeRPSU Gear & Maintenance 3 09-26-2008 06:46 PM
Replacing my fuel tank this Spring, and need your sage advice. ChicagoNewport27 Gear & Maintenance 12 06-04-2008 08:39 PM
My First Haulout Dan Dickison Her Sailnet Articles 0 04-04-2002 08:00 PM
