Old 02-14-2011
Leocat66's Avatar
Leocat66 is on a distinguished road
Whale Gusher 10
We have just installed a Gusher 10 MK 3 Manual Bilge pump and it will not work. It was being used in the past as a transfer pump on a level installation, and worked just fine. Does anyone know how much lift this pump should have? We have checked all hoses but have not taken it apart to check the valves.
Old 02-14-2011
I seriously doubt the lift is the issue, since the specifications say it is good for 4 m (13.5 ft) of self-priming or max head. Of course, if you're using non-smooth wall hose, this will be less.
I would also recommend you learn how to use Google.com. My first search for "whale gusher mk 10 specifications" found the Whale website page for the pump with all the specifications. Also, would recommend you read the POST in my signature to learn how to get the most out of sailnet.
Old 02-14-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Most likely there's a problem with the check valves. If it was working properly before, taking it out of its previous location, and reinstalling it in its new location, may have knocked a stray bit of gunk so that its now between the valve and its seat. Since you have to take the diaphragm off to look at the valves anyway, look closely for cracks in the diaphragm; sometimes such cracks are far from obvious.
While the smoothness of the hose will influence flow rate, it should have little or no effect on the max head. Max head is a function of the vacuum that a pump can generate without any fluid in it (i.e., "dry"), with the max possible for water being about 10 meters. Since the pressure difference between the pump and the intake end of the hose doesn't really depend upon the flow rate of the air in the hose, smoothness isn't important for max head.
Old 02-14-2011
kismetc30 is on a distinguished road
make sure..
you did not plumb it backwards.
Old 02-15-2011
Leocat66's Avatar
I used google and did find a neat exploded diagram. Searched for a manual, and could not find one, neither did I see the specs. Thank you for the info. on the lift specs. Sailingdog. Sorry to bother you. By the way, Google has been working just fine for me for several years, I obviously missed it and will try again.
It is plumbed properly, but I will check again today just to make certain. We are using smooth surface hose with double clamps. We have a kit and will check the valves. The pump is in tight quarters, in the only available location, and cannot be serviced in place, as we have a very traditional cutter and not much room in the cockpit. Before we take it out we wanted all the suggestions available.
Old 02-15-2011
mitiempo's Avatar
Marine : Whale Pumps 12V Henderson Plumbing Bilge Diaphragm Submersible Pressure Water Systems Marine Caravan RV Shower Drain Portable Sanitation Purging Groundwater Solutions Voltage Electric
Most manufacturers have instructions and manuals on their site
Brian
Old 02-15-2011
Leocat66's Avatar
Thank You mitiempo, it is much appreciated.
Old 02-15-2011
RainDog's Avatar
Not Finished Yet
RainDog is on a distinguished road
I have had mine do this twice now. It does not take much for it to lose suction. Try sucking on the inlet side. You should not be able to get *any* air. Try blowing on the outlet side, you should not be able to blow *any* air. If either of these tests fails, you have to rebuild the pump. One of the "flaps" is not sealing properly. I normally just have to take it apart and clean it. If the rubber is at all brittle, or you cannot get the flaps to seal, buy the rebuild kit and rebuild the pump.
If both the tests work, but you still cannot pump, I would suspect a hold in the hose. Try sucking on the hose form the bilge and see if you can notice a leak. Also blow on the output hose and make sure it is not blocked.
Pacific Seacraft 34 #142
Seabrook, Texas
Old 02-15-2011
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Ensure that your diaphram is not damaged. They don't last forever and if the pump previously pulled any oil contaminates the vales and/or diaphram may have deteriored enough to allow an air leak, however minor. They are certainly not very sophisticated pumps, hence their reliability, but they do tend to deteriorate over time.
FWIW...
Old 02-15-2011
Leocat66's Avatar
Checked the plumbing again and it is correct. Pulled the pump and found some corrosion around the valves, but I am not sure it is enough to prevent it from working. Found the valves to be a bit stiff. Cleaned the pump and re-surfaced the outlet plate with JB Weld where there were minor pits. I have a kit, but may need a new out flow plate also. Found no issues with the diagram, but will be replacing it along with the valves since the installation and removal is really difficult.
If this works, with an off the boat test first, I will probably order a new exhaust valve plate and a new kit for a spare.
Thanks to all for the prompt support and suggestions, it is much appreciated.
Look Out! Whale!!! night0wl General Discussion (sailing related) 77 07-24-2010 06:34 PM
Water filter on a Gusher Galley 3 gpm foot pump? SanDiegoChip Gear & Maintenance 2 05-20-2009 02:28 PM
Whale in SD Bay poopdeckpappy General Discussion (sailing related) 46 04-09-2009 04:18 PM
Whale Gusher Pump Question harbin2 Gear & Maintenance 24 01-15-2009 01:54 PM
Whale of a problem billyruffn General Discussion (sailing related) 26 08-25-2008 11:45 PM
