02-16-2011
In many cases expensive liferaft holders are equipped with hydrostatic releases, which will release the raft automatically if the boat sinks. Mounting it in the cockpit, not on the pushpit rails or forward of the companionway, is probably the best place for it. If it is on the pushpit rails, it can be damaged or torn loose, as is the case if it is on deck. In the cockpit, it won't block the view of the helmsman either.
It would help a lot if you said what kind of boat you had, since someone here may own one and have suggestions for liferaft canister placement.
