Old 02-17-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Mooring gear inspection or replacement
I bought mooring gear from a guy this past fall. He said the chain was replaced 2 years ago. Should I hire a 'professional' diver to inspect the equipment? I tend to be a DIY sort of person. Is this something I could do? What could they possibly see that would prevent a failure? Or what could I possibly see that would prevent a failure? Should I just forgo the inspection, and replace the chain every few years? Or is that completely impossible with just a snorkel, mask, and fins?
Sailing newb
Mooring newbier
Old 02-17-2011
klem is on a distinguished road
Are there any local regulations about inspections? Most mooring fields have regulations regarding how often a mooring must be pulled from the water or inspected or both. If they require a diver to inspect it, you won't be allowed to do it yourself, you will need someone else.
If there are no requirements, I suggest inspecting yourself provided that you have the equipment and know-how. Just replacing the chain every few years will be very costly and may not actually prevent a failure as there are some conditions where deterioration takes place quite quickly. Here is a quick list of stuff to check while inspecting, there are probably some things that I am forgetting.
Make sure chain isn't wrapped around anchor
Make sure anchor looks to be dug into the bottom
Inspect all chain links, shackes and swivels for excessive corrosion
Inspect anchor for excessive corrosion
Make sure all shackles are properly seized
And don't forget to check your pendants even though you don't need to dive for them
Old 02-17-2011
Clem's point about the local regulation requirements is key. Some places require that you have the gear inspected periodically. Your insurance company may also require that you have it professionally inspected.
Old 02-18-2011
Barquito's Avatar
Barquito
Thanks for the input guys. We don't have any requirements for inspection in our harbor. However, if my boat was set free it would plow through about 20 other boats, so I think I may just hire a pro.
Old 02-18-2011
Dd you check with your insurance company? If not, you should, since they may require you to use a specific inspector or one of a group they have already vetted.
Old 02-18-2011
HPLou is on a distinguished road
Send a message via AIM to HPLou
It also helps to know what type of mooring anchor you have, mushroom? helix? If you have a mushroom anchor you should haul it for inspection at least every two (2) years for a complete inspection of chail, shackles, swivels, etc. If it is a helix type the a diver would be required to inspect/replace as needed.
Old 02-18-2011
QuickMick's Avatar
QuickMick is on a distinguished road
have to agree wholeheartdly. if they do have requirments and you dont meet them, your 'would plow into 20 boats' scenario would cost you dearly as im fairly sure they would deny any claim.
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 02-20-2011
Barquito's Avatar
Barquito
Good point. I will look into that.
mooring gear jwjab General Discussion (sailing related) 4 10-16-2010 02:39 AM
Mooring pendant replacement LarchmontDana Gear & Maintenance 3 10-02-2010 07:57 AM
Gear confessional: what was the last piece of gear you bought merlin2375 Gear & Maintenance 60 07-05-2008 10:45 AM
Pile Mooring - Mooring Line Stretch? lrak Gear & Maintenance 2 06-12-2008 07:59 AM
Mooring Gear talessi Gear & Maintenance 2 11-17-2004 05:04 PM
