Old 02-18-2011
n8kraft's Avatar
Commodore
n8kraft is on a distinguished road
Catalina 27 gas tank replacement
Hi all,
Last fall I winterized my boat and left for a Navy deployment on my ship, USS Momsen. My wife went to check on our boat, a Catalina 27 from 1973 and smelled gas and saw the remnants in the bilge. One of my buddies checked out the fuel lines and connections and it looks like I've got an old leaky gas tank. The offending tank is located under the starboard berth and connects to the original Atomic 4.
Since I'm still not home I'm planning to get the boat moved to the maintenance yard in Everett where the old tank will be removed, a new tank manufactured and the new one installed. A new tank direct from Catalina is $585 plus shipping. I don't feel bad having one made close to home.
Is there anything else I should be considering?
-Nate
Old 02-18-2011
tommays's Avatar
You do need to be sure they have the ability to sticker and certify the tank and make a no-hassel everything in the same place copy
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 02-18-2011
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
N8,
I'd thoroughly check out the old tank before discarding. Some of the early tanks used were made of Monel, at least they were with the Tartan 27's - not sure about C 27. It may be that some of the fittings have given up and could be replaced, re-using the tank.
The tank could be shot though. $585 sounds pretty steep for a new tank. There are fuel tanks available from a number of sources that you might consider. Defender seems to be having a sale on Moeller tanks right now and even the SN store probably sells them too. I'm not sure how tight your tank installation is so you will have to figure the dimensions out yourself.
Good luck sailor!
Old 02-18-2011
tommays's Avatar
By the time i paid shipping i was close to 500 dollars for a custom 14 gallon tank
You cold NOT pay to have a plastic tank with the fume permation issues
Tommays
Northport NY
Old 02-19-2011
capttb is on a distinguished road
Is the $585 price from Catalina Direct ? If so I would call Dani Monterroso at the California Factory 818 884-7700.
Catalina Direct is not Catalina but rather a Catalina dealer, while an excellent source for parts it's a custom tank built for them, you can only hope the factory might do a little better pricewise.
Many times the factory price is better than something you can have made locally.
"Democracy is two wolves and a lamb deciding what to have for lunch, Liberty is a well armed lamb contesting the decision."
Old 03-18-2011
n8kraft's Avatar
Commodore
I've attached a few pictures my wife took and posted them on my blog: Sail Everett
Tank showing corrosion where glassed in to the hull
Lines to cut for replacement
Gunk inside the tank
Capttb: The quote was from Catalina Direct and did not include any shipping or handling fees.
I've just checked out the Moeller site. Looks like I can't buy direct from them so I need to find a dealer. Also, I don't see anything a gauge on the tank for fuel level.
Thanks all.
Old 03-18-2011
WouldaShoulda's Avatar
AEOLUS II
WouldaShoulda is on a distinguished road
Why not cut out the old tank and use the compartment for an 8 gal portable and strap it down??
-$50??
Old 03-18-2011
n8kraft's Avatar
Commodore
WouldaShoulda: Sounds like that could be a fair temporary fix so I can go cruising April 1, but I'm going to be selling this summer and want everything to be good for sale. Having that tank inside can not properly vented makes me nervous too.
Old 03-21-2011
n8kraft's Avatar
Commodore
I found a 7 gallon plastic tank from Kracor that is small enough to meet the height requirements. It looks like if I want to get a replacement tank that's about the same size as the one I have now I need to go custom. Almost 40 years is pretty good for a steel tank though.
Old 03-21-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
n8,
You're right, you definitely DONOT want to use a portable tank below decks, particularly with gasoline.
One of the cool things about translucent plastic tanks is that one can see the fuel level by just looking at the tank from the outside, no gauge needed. You might also want to check out the Vetus fuel tanks. They're a little pricier than Moeller, but they may have one that's a better fit for your application (I had the exact same problem last year with my Cal 2-27, and wound up getting a Vetus tank).
Cal 29 Fuel Tank Replacement dantorch Cal 6 10-22-2010 01:19 PM
Holding Tank Replacement chef2sail Gear & Maintenance 6 01-02-2009 09:00 AM
350 holding tank replacement help please. geop Island Packet 3 06-06-2008 11:47 AM
C-30 Gas Tank Replacement gclayton Catalina 3 10-14-2007 04:52 PM
Fuel tank Replacement samchristo Pacific Seacraft 3 08-06-2007 09:37 PM
