02-19-2011
Originally Posted by SailingWebGuy
The work you described doesn't sound that difficult. I've never ever worked on an engine before and I just finished a minor rebuild on mine. The Moyer guys gave me a lot of pointers and I have a manual. It took me a couple weeks and the only reason it took that long were because of cash delays.
You can do it!!
Here's a before (well, during) and after.
Probably am going to end up doing it myself -- just hoping to keep it contained somewhat and not have it turn into a bigger and bigger job. Part of the fun of an older engine. My A4 has been great and I've done all the work & maintenance on it for the past 3 years.
2 of 3 manifold nuts loosened today and just being patient with the third. Looks as though the center manifold stud was replaced at one point. Expect to remove the carburetor tomorrow and patiently coax that last manifold nut loose (lots of PB Blaster, tapping the nut itself, and tapping a wrench -- both ways). A little nervous about introducing heat (torch) right above the fuel pump.
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
