Soft soft soft - SailNet Community
post #1 of 6 Old 02-20-2011 Thread Starter
Senior in age only!!!
centaursailor's Avatar
Soft soft soft
Sail-World.com : Product of the week: Soft snatch block
Aint this the dogs b*****x.
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
post #2 of 6 Old 02-20-2011
paulk's Avatar
The idea, execution, and ease of use look great. The max line size of 9 mm (3/8") would turn our spinnaker trimmer's hands into meatloaf pretty quick, though. We use thicker sheets for comfort. When is Sailnet going to carry these things, and when are they going to upsize them?
paulk is offline
post #3 of 6 Old 02-20-2011
'Tis clever... and simple. Should be great for twingers.
Wonder about the MSRP...
Faster is offline
post #4 of 6 Old 02-20-2011
I don't discuss my member
zz4gta's Avatar
You could easily make your own. And the if you use larger spin sheets, just tapper the sheet to fit the 3/8 line, should be pretty easy. My spin sheets are 5/16 tappered to 1/4 then tappered again to 1/8" dyneema. Great grip where you want it, and light weight were you want it.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #5 of 6 Old 02-20-2011
paulk's Avatar
Tapering would be the best option if we were in the market for new sheets. Our spinnaker's 1000 square feet. 5/16" would tear off fingers a good puff, so our sheets are at least 5/8".
paulk is offline
post #6 of 6 Old 02-20-2011
zz4gta's Avatar
And you crew doesn't use gloves, winches or ratcheting blocks to help with the load? 5/8" is ridiculous for a boat that uses 1000sq ft chute. The load is less than 1,000 lbs in 15 kts apparent. In light air you won't be using a winch, and the heavy sheets hurt performance. When the wind picks up, you're using a winch anyway, what's one more wrap?
Check out the big boats, they don't have anything that's over 1/2". They just use higher tech lines.
zz4gta is offline
Mobicool, Soft Cooler superiorvoyager Gear & Maintenance 4 02-03-2009 10:43 PM
Soft Deck Repair davidpm Gear & Maintenance 38 12-05-2007 12:54 PM
Soft Stantions lightyear22 Gear & Maintenance 3 02-28-2006 05:37 PM
Soft/Rot Wood on ply in bilge. Rasputin Gear & Maintenance 3 05-11-2001 10:30 PM
