Dealing with a soggy cockpit sole - Page 3 - SailNet Community
 1Likes
post #21 of 52 Old 02-23-2011
mitiempo's Avatar
I would wonder how many done from below in larger areas have or will have delamination issues. Small areas shouldn't be a problem.
Myself and others have given good advice. But it's beersmith's boat and he has to deal with the results, whether good or bad. Looking at his first picture again it would be very easy to cut the top off inside the non-skid area and re-core with gravity on his side. It is fairly obvious that the water entered where the pedestal base mounts. This area should be solid fiberglass to prevent it happening again.
Luck plays no part of it.
Brian
mitiempo is offline
post #22 of 52 Old 02-23-2011
Sunsets and Warm Beer....
LandLocked66c's Avatar
Beersmith, just take your time and try to keep the resin off your head!
Tommays turned out super nice!
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
LandLocked66c is offline
post #23 of 52 Old 02-23-2011
mitiempo's Avatar
As I recall Tommay's boat had an inner skin that was pretty thin and not very self supporting. I don't think he had much choice.
Brian
mitiempo is offline
post #24 of 52 Old 02-23-2011
Recoring from below is often going to be more difficult, since gravity is working against you. It also generally requires working in relatively cramped quarters, especially compared to working on the deck or cockpit.
sailingdog is offline
post #25 of 52 Old 02-23-2011
That's what is so nice about my pop top. I took the cabin top off my boat to re-core it!
S/V Frida
post #26 of 52 Old 02-23-2011 Thread Starter
Sailing to surf
Beersmith's Avatar
I blame Don Casey for telling me it would be preferable to do it from below. Regardless, its too late now! I don't see this project as difficult as many of the others I'm dealing with. At least this is the only area of delamination in the boat.
Now my blister problem, on the other hand, is a bitch:
One
Two
My boat rebuild/sailing blog:
Beersmith is offline
post #27 of 52 Old 02-23-2011
mitiempo's Avatar
beersmith
Here's an interesting link to a great article on gelcoat blisters, best I've seen. You might find it interesting.
Sea Lake Yacht Sales (Kemah, TX)
Brian
mitiempo is offline
post #28 of 52 Old 02-23-2011 Thread Starter
Sailing to surf
Beersmith's Avatar
Originally Posted by mitiempo View Post
beersmith
Thanks for the link!
thats the best take on blisters I've ever read (spent the last year absorbing any and all info about them). He's Dutch also...my heritage, so he gets my nod.
post #29 of 52 Old 06-29-2011 Thread Starter
Sailing to surf
Beersmith's Avatar
Job finished and updated! I edited the first post to include the remainder of the job, here is the update:
UPDATE!
This past week I finally finished the repair work and am excited to have it done. Aside from the hull blisters, this is probably the biggest repair job on the boat. The next step was to grind down the remaining core and get a fairly smooth surface to glue in the new core. Here is the surface post grinding:
I purchased some end-grain balsa to use as the replacement core. Here is the first piece measured and cut. The board underneath it is the backing plate I will use to hold the core in place while the epoxy dries. I covered it in wax paper so epoxy wont stick to it.
After measuring and cutting the core, I painted both contact surfaces (core and sole) with unthickened epoxy to penetrate, then slathered on a ton of thickened epoxy to the core:
Next I smushed it up against the sole undersides, put on the backing plate, then used shower curtain rods to snug it up.
I filled in the edges with thickened epoxy and let the first piece cure. Here it is after it dried:
I then performed the same tasks on the second piece of core. Here are both pieces in place, with the edges sanded round:
Next up I applied a few progressively larger layers of biaxial cloth to the undersides. I used smallish (1 ft or so) strips to keep it manageable while laying up the glass overhead.
ob finished! I will sand it down and paint it along with the rest of the engine room ceiling. I stood on the cockpit sole for the first time in a while and it is solid as a rock!
Lessons learned: doing the job from the underside was a mistake. My initial idea was that working from the underside would ensure the top skin is undamaged and finish/fairing work would be minimized. The glass underneath is rough and unfinished, so the repair work need not be super neat.However, I underestimated the effort it took to glue in the core overhead with gravity working against me. It was extremely messy, with epoxy getting all over me, in my hair and everywhere. My arms were noodles after each work session working overhead. If I had to do this again I would definitely go from the top and just take my time with the finishing work, particularly since I am fairing and painting the decks regardless. Gravity working for you is a good thing. All in all, I am happy with the repair and glad to be moving forward!
post #30 of 52 Old 06-29-2011 Thread Starter
Sailing to surf
Beersmith's Avatar
quoted for truth! good advice sailingdog, and all others who had the same advice. my lesson is learned.
S2 cockpit sole core material timangiel S2 3 03-10-2011 04:47 PM
new core for cockpit sole Grcesq Gear & Maintenance 10 11-17-2009 06:18 PM
Forward deck hatch -- the dreaded soggy wood tomg847 Gear & Maintenance 15 08-27-2008 07:39 PM
Is the cockpit sole cored? timangiel Gear & Maintenance 10 05-11-2007 11:32 AM
Soggy Dollar Bar and Sand Castles being sold JVD VIEXILE General Discussion (sailing related) 4 04-08-2004 02:01 PM
