Moving chainplates outboard (from "through deck" configuration), I have a question.. - Page 6 - SailNet Community
 1Likes
post #51 of 57 Old 02-25-2011
Senior Slacker
SlowButSteady's Avatar
Originally Posted by bljones View Post
A lot of work for no gain. Drill out the bulkhead mounting points for the chainplates and pot with thickened epoxy, use larger hardware, build deck islands out of thickened epoxy to deter water intrusion through the chainplate ports, and call it done. Bigger, stronger, better, faster, cheaper with no change in geometry.
I'm not so sure that the change in geometry would be all that big a deal. Moving the shroud outboard 4 inches would only increase the angle by about one degree. I seriously doubt that the original tangs, etc., were made with a tolerance of less than one degree.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #52 of 57 Old 02-26-2011
Hi , I am in the same situation with my Utzon 30 spidsgatter, with a want to negate as much potential water ingress through deck as possible, The plates I have seen are recessed behind rub rails etc with nice flat sections,I photographed a liberty 30 setup the other day I will try to post same, I will follow your thread with much interest. cheers chris
procrastonator is offline
post #53 of 57 Old 02-26-2011
Guys and Gals.. Since this thread drifted into an engine discussion that I thought had some pretty valuable info hidden behind the 'chainplate' title, I've culled the relevant posts to its own thread.
You'll find it here:
http://www.sailnet.com/forums/diesel...d-replace.html
Carry on!
Faster is offline
post #54 of 57 Old 02-27-2011
Wow, that's pretty good for a 52nd stater... Thanks Faster.
Carry on!
sailingdog is offline
post #55 of 57 Old 10-28-2011
I have had my boat a 48 ft frers 1980 out of the water for 4 months and noticed the
Teak deck cracked across the grain adjacent to the single in line chain plate. I figure this could be due to temporary hogging of the boat, plus drying of the teak plus or either slight movement of the chain plate/s either way, listening to you guys I think I will take a closer look. Ps It's been it's very hot here in Dubai.
Barastiboy is offline
post #56 of 57 Old 10-28-2011
moving chain plates outboard
I've got the same decisions to make.
Barastiboy
post #57 of 57 Old 10-28-2011
Gotta love those channels. Great for standing on when preparing to board a passing pirate ship.Hope the big fenders are out when needed. I've seen outboard chainplates in cast bronze with a T cross section at the top to prevent any flex.Could this be the best of both worlds? Neat and salty.
Capt Len is offline
Outboard Motor Bracket "not for use with 4 stroke engines" petertribo Gear & Maintenance 13 12-02-2014 11:55 AM
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 06:31 PM
gear\clothes\"deck" shoes...? Kernix General Discussion (sailing related) 25 03-24-2007 10:24 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 12:53 PM
