Moving chainplates outboard (from "through deck" configuration), I have a question.. - Page 7 - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 02-25-2011
chrisncate's Avatar
Taco Whisperer
chrisncate is on a distinguished road
Originally Posted by LakeSuperiorGeezer View Post
To outrun storms, how about a top fuel dragster engine, Chrysler Hemi 426, with racing alcohol, 85% nitromethane and about 15% methanol, instead of gasoline. Top fuel dragster Worlds Fastest Cars
That's just silly LSG..
I need practical...
Reply With Quote Quick reply to this message Share with Facebook
  #62
Old 02-25-2011
Large Member
mdbee is on a distinguished road
I will take your word for that
"Urine is salty"
Originally Posted by bljones View Post
Urine is salty. Potato chips are salty. Which would you rather ingest?
Sometimes, salty is a bad thing.
oooooh, sig line!
  #63
Old 02-25-2011
LakeSuperiorGeezer's Avatar
LakeSuperiorGeezer is on a distinguished road
I need practical...
Quite true, so about the 2GM20, does it have fresh water cooling (heat exchanger) or has salt water been eating at its insides.
  #64
Old 02-25-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
A lot of work for no gain. Drill out the bulkhead mounting points for the chainplates and pot with thickened epoxy, use larger hardware, build deck islands out of thickened epoxy to deter water intrusion through the chainplate ports, and call it done. Bigger, stronger, better, faster, cheaper with no change in geometry.
I'm not so sure that the change in geometry would be all that big a deal. Moving the shroud outboard 4 inches would only increase the angle by about one degree. I seriously doubt that the original tangs, etc., were made with a tolerance of less than one degree.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
  #65
Old 02-26-2011
procrastonator is on a distinguished road
Hi , I am in the same situation with my Utzon 30 spidsgatter, with a want to negate as much potential water ingress through deck as possible, The plates I have seen are recessed behind rub rails etc with nice flat sections,I photographed a liberty 30 setup the other day I will try to post same, I will follow your thread with much interest. cheers chris
  #66
Old 02-26-2011
chrisncate's Avatar
Taco Whisperer
Thanks! Feel free to check out my site in my sig and email me with any progress you make as well, I'd be interested to see your progress and what you come up with.
  #67
Old 02-26-2011
Guys and Gals.. Since this thread drifted into an engine discussion that I thought had some pretty valuable info hidden behind the 'chainplate' title, I've culled the relevant posts to its own thread.
You'll find it here:
http://www.sailnet.com/forums/diesel...d-replace.html
Carry on!
  #68
Old 02-26-2011
chrisncate's Avatar
Taco Whisperer
Carry on!
Nice, thanks!
  #69
Old 02-27-2011
Wow, that's pretty good for a 52nd stater... Thanks Faster.
Carry on!
  #70
Old 10-28-2011
Barastiboy is on a distinguished road
I have had my boat a 48 ft frers 1980 out of the water for 4 months and noticed the
Teak deck cracked across the grain adjacent to the single in line chain plate. I figure this could be due to temporary hogging of the boat, plus drying of the teak plus or either slight movement of the chain plate/s either way, listening to you guys I think I will take a closer look. Ps It's been it's very hot here in Dubai.
You may post attachments
You may edit your posts
Outboard Motor Bracket "not for use with 4 stroke engines" petertribo Gear & Maintenance 13 12-02-2014 11:55 AM
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 06:31 PM
gear\clothes\"deck" shoes...? Kernix General Discussion (sailing related) 25 03-24-2007 10:24 AM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 12:53 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
