Old 02-22-2011
Capslock118 is on a distinguished road
Installing depth-finder in-hull
Hi There,
So we are near purchasing a 25' sail for the first time.
I've always had a depth finder on motor boats prior, generally more for the fish finder part though I can never catch fish
some depth finders allow the sonar to be installed inside the hull.
I am playing with the idea of installing a depth finder for the sail boat, again mainly for fishing and inside the hull rather than drilling through the hull to mount outside. But maybe this is a useless item and my meager budget would be better spent elsewhere.
what are your thoughts? do you own a depth/fish finder? if so, have you installed inside the hull? any problems come up doing that?
also, if installed in the hull, if I reversed the sonar so the part that is suppose to face toward the bow is now facing the stern, would I end up with readings ahead of the boat or is that not how it works?
it would be good to see depth ahead if that's how it works.
You can call me Joel.
Old 02-22-2011
QuickMick's Avatar
QuickMick is on a distinguished road
I hooked up my hummingbird this way, works like a charm. i put it in a bag of water(which im not sure if you need to do) and moved it around till i liked reading, removed from bag and epoxyed it to the fiberglass (after a decent cleaning), when i pushed it down into the epoxy, i kinda used a twisting motion to get rid of any bubbles. there is another method with mineral spirits filled pvc but i didnt go that route. what your boat is made of is a consideration, as well as not forgetting to offset the unit to keel depth.
mine is in the engine compartment, but i use that unit primarily for fishing from the cockpit, and do have redundancy via thru hull unit. if you are worried about grounding id put the transducer toward the bow to 'see' what is in front of you.
good luck
edit: while i maybe off base, i believe the number of 'beams' affects size of area you can view-spinning the transducer wouldnt affect the range, persay just make everything on the scrolling display be backwards... i think~that last bit was giving me a headache... lol.
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 02-22-2011
copacabana is on a distinguished road
Rather than glue it with epoxy, you can use silicone. The advantage of silicone is that you can always remove the transducer at a later date or move it to another place. It has to point down to read the bottom (ie. in the same orientation it would be in if attached to the outside of the hull). It won't read ahead of the hull. You can try installing it ahead of the keel, but the millisecond warning it will give you before you run aground won't do you much good. It's best to find a place that has no turbulence and won't be out of the water when heeled over. I installed two in my boat and both work fine. Don't drill holes in your hull if you can avoid it!
Vindö 50
Old 02-22-2011
Forward looking depth sounders are available, but are pricey, use bulky transducers and are not 'the norm'.
Generally your depth indication is going to be whatever's directly below the transducer, wherever that is. Most are mounted ahead of the keel to give you a (very little bit of) warning, and only if you're going very slowly. Mounting ahead of the keel also minimizes interference from vortices and disturbances to the water that can confuse the sounder (as an example watch your sounder readings anytime you're reversing at some revs, or if you're backing down hard... the number is often all over the place)
Epoxy, silicone, or liquid cavity mounts are ways to mount inside the skin of the hull. I think it works better in single skin hulls vs cored hulls, and you will lose some range but it does avoid the issues with adding a through hull fitting.
A transducer intended as a through hull will probably need to be mounted in the lid of a liquid cavity style installation.
1984 Fast/Nicholson 345
Old 02-22-2011
mitiempo's Avatar
They will not work in a cored hull, but even cored hulls are usually solid fiberglass along the keel. Any epoxied transducer can be mounted inside. On my current boat I installed a Raymarine ST-40 and it comes with an Airmar transducer designed to be mounted in a drilled hole. I just removed the nut and gasket and epoxied it in. I installed it under the aft most part of the V-berth, on the centerline. You will get less disturbance in this location. As posted above place the transducer in a baggie of water and check that your chosen location works first.
Brian
Old 02-22-2011
Joesaila's Avatar
1977 Morgan OI 30
Joesaila is on a distinguished road
I gonna do this! I want to connect it w my garmin chartplotter w/o drilling another hole in the hull. The original digital unit is only about 90% correct. It seems to blink off at the most inconvenient times. THANKS FOR THE GOOD POINTERS!
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Old 02-22-2011
mitiempo's Avatar
YOU"RE WELCOME
Brian
Old 02-22-2011
sailor50 is on a distinguished road
This months SAIL MAGAZINE addresses this issue right to the point.
Old 02-22-2011
mitiempo's Avatar
It is also addressed here: WEST SYSTEM | Modifying and Customizing Boats - Depth sounder installation
And as they state most manufacturers of depth sounders recommend epoxy for installing the transducer. Less chance of bubbles.
Brian
Old 02-22-2011
In a somewhat related question:
We've recently upgraded to a compact plotter/depthfinder and we already have an aging but functional Signet DS. I'd like the expanded features of the newer/smarter depthsounder capabilities, and the internal install has appeal for obvious reasons.
Anybody think there would be cross-talk between two simultaneously operating systems? The new one has selectable Hz settings - should I make them different? I'm thinking of mounting them some distance from each other.. Any thoughts?
Depth finder geolarry Electrical Systems 1 08-27-2008 07:39 PM
Depth Finder ozarkmom43 Gear & Maintenance 2 06-13-2008 09:12 AM
depth finder buckbob Gear & Maintenance 5 04-16-2008 10:12 PM
Depth Finder Duke 7184 Gear & Maintenance 6 09-18-2007 10:36 PM
depth finder duffyM Gear & Maintenance 1 11-22-2001 05:15 PM
