02-23-2011
Chastened
Originally Posted by celenoglu
1. Connection problems: Although rare, check the cables. The connections to the dials and mast top are more probable.
2. The unit on the might be defective. This is generally a circular potentiometer which can rotate 360 degrees. This might be defective. In this case it is best to replace the whole unit. But it might be possible to repair it in some cases.
I agree with this. In the case of #1, you can perform a continuity check on the cable with an ohm or multi-meter. You can also put the multi meter on the plug of the potentiometer and spin the wind vane. If the resistance reading is "open" or "infinite" or it doesn't change at all when rotating the wind vane, then the problem is there.
I have an ancient (broken) Signet knotmeter, and found that they were still in business. Definitely check out their website. They offer drop-in replacements for some of their instruments.
S/V Old Shoes
1973 Pearson 30 #255
