Old 02-24-2011
Kandahar is on a distinguished road
jib roller furler halyard swivel
I just purchased a boat - luders 33- that has an old Hood roller furling jib. The surveyor mentioned that the system would need to be replaced soon. He only was looking at the bottom section and did not have a chance to see the halyard swivel unit as the sail was up during his inspection. When I saw the boat the sail was off and I was able to see the swivel unit. The top plastic cover was broken off and I could see inside the unit. A white core inside the unit looked like it was either split in two - by design or cracked - not sure which. A metal locking ring looked somewhat rusted. The mast has usually been left up while in the yard so the unit has obviously been exposed to the weather for quite some time. Should I worry about the forestay letting go or is the worst that can happen a jammed roller system? Any feedback or experience with this would be greatly appreciated. Thanks - Paul in Essex.
Old 02-24-2011
knothead's Avatar
Paul, You don't have to worry about the condition of the halyard swivel affecting the headstay unless it is frozen and you force it. What can happen then is what's called halyard wrap which can cause a headstay failure.
The two piece plastic thing you see is simply a bushing which helps the halyard swivel ride smoothly over the aluminum extrusion.
The extrusion rides/rolls on the headstay wire and is entirely separate in your system.
If your swivel and drum bearings are working properly and the spiral ring is not too badly corroded, I would recommend that you simply clean/rinse it well and apply some light lubricant such as WD 40 to stop the corrosion and keep using it.
If it's not working as well as it should be, the bearings can be replaced.
Ron Paul 2012
"wikijar"
Old 02-25-2011
thanks
Thanks for the feedback. This is one replacment cost we were not ready to deal with this year. My biggest concern was having the headstay fail as you can imagine. Thinking about it know I understand they are independent of one another. You guys on sailnet are fantastic. Never knew there was such a resource until my boat partner sent a thread to me. Again, thanks for the advice Paul
Old 02-25-2011
baboon is on a distinguished road
One other thought. You should make sure the top swivle is in good shape even if it is not damaging the other rigging. Mine (not a hood) failed and jammed with the sail half furled. In that situation you can not lower the sail, a real problem if it is blowing hard. Check you berrings or bushings, clean it out well, and consider replacing broken parts even if you do not think they are critical. The manufacture may have parts available, and some riggers like Rig Right can help.
jib furler/reefer and halyard MtHopeBay Gear & Maintenance 19 02-22-2012 12:31 PM
Tangling Furler/Halyard Benobo Gear & Maintenance 17 06-16-2010 10:29 AM
Furling Halyard Swivel Problems sundog01 Gear & Maintenance 6 06-03-2010 01:01 PM
halyard replacement-rolling furler QuickMick Gear & Maintenance 3 11-14-2009 10:53 AM
Roller Furler ID? (w/Pic) Seafire327 Gear & Maintenance 6 05-21-2009 09:28 PM
