Old 02-25-2011
sqwishalot's Avatar
sqwishalot is on a distinguished road
How to prep an embossed diamond pattern deck for paint?
I have a Yachbau 30, 1976 model. It needs deck, cabin, topsides paint.
I have a deck that has the nonskid pattern molded into the finish. If I sand it, it will have to be taken down 1/16 inch or more to even out.
My guess is to strip it chemically to leave the embossed ridges. Or just clean it well, and not sweat it, and just add another coat. This will diminish the non skid properties.
I already searched the forums, and I know my ass is full of crap already, so if you have something constructive to recommend, that would be great.
Old 02-25-2011
A thorough scrub with TSP, followed by a thorough rinse might be enough. Let it dry completely, mavbe follow up with a tack cloth, and/or a solvent wash prior to painting.
One of the issues here is the paint itself may fill/obscure the original pattern, but you can always add some grit to the paint, or use a product like Interlux Interdeck which already contains the grit, to actually improve the nonskid properties above and beyond that of the original pattern.
A two-part paint will have more durability at, of course, higher cost and complications of premixing.
1984 Fast/Nicholson 345
Old 02-25-2011
QuickMick's Avatar
QuickMick is on a distinguished road
here are a couple of links, when you search the forums you will have better luck using google and searching sailnet and topic xxx...
oh, but dont type topic. lol.
http://www.sailnet.com/forums/gear-m...-non-skid.html
http://www.sailnet.com/forums/gear-m...-topsides.html
http://www.sailnet.com/forums/gear-m...kid-paint.html
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 02-25-2011
Personally, I'd sand the non-skid areas and then paint with a good non-skid finish. Kiwigrip, durabak, or using a non-skid paint or non-skid additive to regular paint makes more sense than trying to preserve the diamond non-skid pattern which will get filled with paint and be rendered fairly useless. It'll also suck up a lot of expensive paint for no real return.
Old 02-26-2011
georgefmys is on a distinguished road
Though applying another non-skid finish after minimal prep of the diamond tread will work fine,it never looks that great.This method works well:Tape off and sand the pattern [about halfway] Then roll on 3-4 coats of a hi build epoxy primer,all coats can go on same day. Then re-sand,if you put on enough primer,surface should be smooth or have only slight pattern that 2-3 coats of topcoat can cover. Kiwi-grip or Durabak would probably do it in one coat,but if you prefer a more subtle texture the flattened Awlgrip method cant be beat for toughness and longevity
dumb paint prep question moonie5961 Gear & Maintenance 11 04-11-2010 12:21 PM
Bottom paint prep, chipped paint josrulz Gear & Maintenance 16 02-14-2010 08:24 PM
Bottom Paint Prep jason3317 Gear & Maintenance 33 03-20-2009 09:45 AM
Removing paint from Diamond pattern Non Skid Finallybuyingaboat Gear & Maintenance 0 09-04-2008 08:15 AM
Which sander for paint prep? theArchitect Gear & Maintenance 9 05-17-2007 10:10 PM
