Old 02-26-2011
Hudsonian is on a distinguished road
Some have fabricated toerails of star-board to provide a low maintenance replacement for wooden toerails. They may harmonize with the traditional design of your boat better than aluminum toerails. The star-board can be worked using standard woodworking tools. I've seen lengths successfully joined with "plated scarf joints" using the deck as the joint plate. If you Google "Star-board" and "plated scarf joints", you'll find descriptions of the tasks to assess whether your skills will allow sucessful completion of this task.
  #12
Old 02-26-2011
But starboard is not very strong as a structural material.
  #13
Old 02-26-2011
mitiempo's Avatar
I'd use the aluminum toerail. Starting at one end it should bend into place fairly easily. It will be much more useful than wood (or starboard which isn't a solution for everything) and won't have the issue of moisture under it as wood eventually does. The "T" section of aluminum toerail should bend as well as "L" section - it is the horizontal section that will resist bend the most, the vertical section should not resist much.
Brian
  #14
Old 02-26-2011
baboon is on a distinguished road
I would like to hear from someone who has actually bent on a metal rail. The original posters boat and mine have a similar profile. Here is an alberg 30
The toe rail has a lot of curve to it compared to modern boats. I know it can be done, I just wonder how much work it really is. Perhaps builders pre-bend them on a form prior to bolting to hull. One worry is that the amount of force required to bend an L or T section profile over the fiberglass could cause damage to the boat. I do not know this, but aluminum is really stiff stuff.
Toe rail: Replace existing mahogany, or go with aluminum?-218__300x_alberg30-layout.gif
  #15
Old 02-26-2011
Given the actual bend is fairly gradual over a fairly long distance, the forces required aren't all that high. Many materials that you would consider difficult to bend and stiff would make the bend along the hull-deck join on a boat with little trouble.
  #16
Old 02-26-2011
mitiempo's Avatar
There are no sharp curves, but a gentle bend over 35 or so feet. I doubt a builder would prebend the rail. They probably use a few people to hold it while others put bolts on.
Brian
  #17
Old 02-26-2011
chrisncate's Avatar
Sup
chrisncate is on a distinguished road
Thanks for all the great input everyone!
I do appear to have the Irwin type hull to deck type construction, there might be a slight indent of 1/4 to (I doubt) 1/2 inch where the toe rail is bedded, I am still not sure and won't be until I pull a piece of the rail up and lay eyes on it.
It seems to me that the aluminum rail would conform to the shape if I bolt either the forward or aft section on first, then just use the leverage the rail itself would provide by being so long (34'). I think I could just bolt one end down, then make the bend by pulling in one the opposing end, bolting as we go. What do you guys think?
Also, I made sure to look and verify that every single thru bolt is in a location that I can lay a wrench on, and they are (gotta love the Alberg).
I wonder if heat would help in making the bends if needed? Bad idea? I could have a torch handy and apply heat as we make the bend and bolt as we go..
  #18
Old 02-26-2011
chrisncate's Avatar
Sup
the other big questions is aesthetics I guess.. I certainly don't like the way the metal rail looks on a classic boat like mine, but functionality has to win out at the end of the day for what/where we wish to sail her someday soon.
I could paint it wood color I suppose....
  #19
Old 02-26-2011
I do think heat would be a bad idea... it won't do the anodizing any good and may cause severe discolouration. As I indicated before, attaching one end and applying pressure with some friends as you drill/bolt your way along should do it.. but you'll need some space/clearance alongside as you deal with the exit angle and the sheer changes while you bend.
  #20
Old 02-26-2011
Bad idea. Not only can it discolor the anodization, but if the aluminum is heat treated for strength, it will ruin the heat treatment and weaken it considerably.
You may post attachments
You may edit your posts
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
Aluminum toe rail shantijwk Gear & Maintenance 4 05-15-2007 11:49 AM
Dirty Rub Rail: Clean it or Replace it? ChicagoNewport27 Gear & Maintenance 6 04-28-2007 02:11 AM
refinishing aluminum rub rail shmangasarian Gear & Maintenance 1 01-13-2006 04:54 AM
Aluminum Rail DirtManly Gear & Maintenance 0 05-01-2001 05:17 PM
SEO by vBSEO 3.6.1
