02-27-2011
If you're looking to upgrade/replace your rigging, my recommendation is to replace the upper terminals with swaged ones, and the lowers with mechanicals, my preference being Hayn HiMods, rather than the more expensive Norseman or Stalocks.
I would recommend you use open turn buckles, as they tend to do better with respect to corrosion issues. The turnbuckles should have toggles on them to prevent fatigue related failure.
