Old 02-28-2011
ilikerust's Avatar
1968 Pearson Wanderer 30
ilikerust is on a distinguished road
Anybody have experience with Reedville Propeller Company?
Based on what I learned yesterday, I need to get a new prop shaft coupler and get it fitted and faced.
So I did a little Googling and found Reedville Propeller Company in Reedville, VA, which claims to be able to do that kind of work.
Does anyone have any experience with them?
Thanks.
- Bill T.
- Richmond, VA
"Twenty years from now you will be more disappointed by the things you didn't do, than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
- Mark Twain
Old 02-28-2011
sawingknots's Avatar
sawingknots is on a distinguished road
any competant machinist with a lathe can do that [just ask locally]
Old 02-28-2011
Maine Sail's Avatar
I can highly recommend Ron Peck at New England Propeller in MA. He is very, very good and very reasonable. He is currently at the NE Boat Show in Boston but will likely return your call anyway. You can also call and ask for David he's the shafting guy..
The shaft you get will be trued to within .001" - .003", most shops never even look at new shaft straightness, and he will ship to you if you can provide your measurements. His fitting and facing and shaft truing is excellent.
He uses only top quality shafting, AQ22, from Western Branch metals and does it right.
If you actually need prop work there is only one shop I recommend and that is Accutech Marine in NH. NE Prop also deos good work but Larry & crew are AMAZING. They do props to 62" shipped in from all over the world and they use both the Prop Scan and Hale MRI machines and provide you will full before and after reports.
I have seen & felt the before and after results and there is NO comparison between Accutech and anyone else I have found. A local Maine shop, which will remain nameless, also claims to be a Hale MRI shop and gives printed report but there is no way their reports are accurate and they are likely manipulating the reports which CAN be done in the Hale software. Report manipulation can not be done on the prop scan machine. I have seen the same prop come from this shop, get installed and have serious vibration issues and be shipped to Accutech and come back smooth as glass..
These guys are FANATICS and can solve just about ANY vibration issue.
______
-Maine Sail / CS-36T
Old 02-28-2011
ilikerust's Avatar
Maine Sail -
I hope you're not telling me now that I can't reuse my existing prop shaft - because it's in great condition and as far as I can tell doesn't need to be replaced.
Thanks.
- Bill T.
- Richmond, VA
- Mark Twain
Old 02-28-2011
ilikerust's Avatar
P.S. - I've never noticed any vibration issue - I'm just doing all this work while I've got the engine out of the boat. One thing led to another and next thing you know I've got the whole prop shaft out and disassembled. New stuffing box and hose will be in the works as well...
- Bill T.
- Richmond, VA
- Mark Twain
Old 02-28-2011
Maine Sail's Avatar
Bill,
If your shaft is good you can certainly re-use it but I would have them at least check it for true while you have it out.. All you'll need is a new coupling fitted & faced, should be $85.00 - $130.00+/- depending on where you are and the shops rates.
______
The SailingDog Toy Company sailaway21 Off Topic 18 07-21-2008 09:52 AM
any experience with this company? shadypark Gear & Maintenance 2 05-21-2008 12:50 PM
Reedville Bluefish Derby beej67 General Discussion (sailing related) 6 04-29-2008 02:56 PM
Distance from Reedville to Solomons brak Chesapeake Bay 7 03-30-2008 10:07 PM
Rigging company Gulfislander Gear & Maintenance 3 12-20-2007 10:08 AM
