Shaft seal leak - Page 2 - SailNet Community
post #11 of 16 Old 03-01-2011
Originally Posted by MJBrown View Post
If you have a Volvo shaft seal there are no adjustments. The only maintenance is relubing the lips of the rubber bellows around the prop shaft. I assume when they replaced the shaft they reused the Volvo shaft seal. If your unit has a hose attached to a nipple check it for a leak. Look but don;t touch!!! Earlier models were metal and need to be replaced every few years. WARNING do not mess with it unless you can be sure to be hauled on a moments notice. The typical failure mode is the nipple breaking off flush with the shaft seal. Once that happens there is no way to stop the water ingress and unless you're hauled ASAP you will sink.
One quick way to stop the water ingress is to put some plumber's putty or modeling clay in the hole and then wrap it with the silicone-self-fusing "rescue" tape. That will often hold it long enough for you to get the boat out of the water. Carrying a couple rolls of the stuff aboard your boat, in the emergency tool kit, is usually a good idea.
sailingdog is offline
post #12 of 16 Old 03-01-2011
i apologize for giving you false info.bad advise is much worse than no advise
sawingknots is offline
post #13 of 16 Old 03-01-2011
October Moon B43
Dog, the way the seal is mounted it would be a real struggle to wrap tape around the seal. Now maybe a repeat act of the little Dutch boy and the dike might work
MJBrown is offline
post #14 of 16 Old 03-01-2011
That is why I mentioned the need for plumber's putty or modeling clay.
Had a plastic stopcock on a Yanmar diesel inboard blow out on me last summer on a friend's boat. We fixed it by jamming the cut off tip of a pencil into the opening the plastic bit left behind and then wrapping it with Rescue tape. It held for long enough for us to get back home (three days away) and get it replaced. Interestingly, the piece that broke is discontinued, and the replacement piece uses a bronze stopcock, rather than a plastic one.
post #15 of 16 Old 03-01-2011
October Moon B43
Amazing what you can do when you have to isn't it? Sounds like a good McGyver fix.
MJBrown is offline
post #16 of 16 Old 03-01-2011
Did much the same on a transmission oil cooling line many years ago on a Ford E350 van using a leather keycase and some speaker wire. That repair lasted over 3,000 miles, mainly because my father forgot I had done the repair and didn't replace the transmission cooling line until he saw it on the next oil change.
Pss Shaft Seal Magic1 Gear & Maintenance 16 10-07-2010 01:03 AM
PSS shaft seal Windborn Gear & Maintenance 26 02-01-2009 10:10 PM
Using spray foam to seal a leak Survivor Gear & Maintenance 10 11-10-2008 01:47 PM
PSS Shaft Seal Question danielgoldberg Gear & Maintenance 16 03-24-2008 11:53 AM
Shaft seal Edo Kazumichi Gear & Maintenance 9 11-23-2006 11:03 AM
