03-01-2011
Originally Posted by scottyt
yes and no SD, yes i wanted to know if the half pint can, can do the stripes. and i stated wrong, by topside i meant the deck, should have said the deck
i also want to paint the deck, which i figure is about 200 to 250 square feet if i include the non skid and vertical parts of the cockpit.
If you're painting the deck, cabintop and cockpit, what I would recommend is removing as much of the hardware as you can. Mask off the non-skid areas cutting into the non-skid area by about two inches, and then paint the "smooth" areas with whatever paint you are planning to use. Then mask off the "smooth" areas and paint the non-skid areas with something like DURABAK or KIWIGRIP. This will minimize the amount of paint you need and give you a very good non-skid surface.
On any paint job, 95% of the work is in the preparation, and that will make or break the paint job. Even an expensive two-part LPU paint won't last very long or look very good unless the prep was done properly.
