Old 03-02-2011
tausap is on a distinguished road
Bleeding hydraulic steering
Hi All,
I am having a problem bleeding my hydraulic steering and hoping for some help. I have bled hydraulic steering before, but this system is completely different than any I have worked on in the past. It is a custom system which is a mix of different components, done 2 owners ago, and not much reference material. I will try to describe it. It is installed on a 1980 Morgan 461.
The steering cylinder/arm attached to the rudder is a Hynautic K-25, which I just removed and rebuilt due to a leaking seal. The original Hynautic system should have had a pressurized reservoir, but this system does not. The helm pump is an AutoNav 904. Plumbed into the system in the engine room are two hydraulic autopilot pumps, a WH P3c as the primary and an AutoNav as the backup. This is a 2-line system with lines which run from the helm unit directly to the Autopilots, which then run to the steering cylinder. There are no bleed nuts on the cylinder, and none on the AP pumps that I can find. There are two bleed nuts on the back of the helm pump. The only fill port is a relief valve/fill nut on top of the helm unit at the wheel.
I have already tried bleeding from one of the helm pump fittings and that was going fine as long as I was turning the helm to Port. Fluid and air were coming out and I kept adding fluid and turning the helm until only fluid came out. I then tightened that valve and opened the one on the stbd side and started to turn the wheel to stbd, but all of the sudden fluid started backflowing and pouring out the fill hole. I stopped doing this and tightened up all bleed valves and closed the fill hole. I tried the helm to full port and could still hear and feel air in the system, and then when I went to full stbd, fluid would run out the relief valve/fill nut.
So now I am stymied.... I am not really sure what is happening and why fluid would backflow out when turning to stbd, but still suck down into the system when turning to port (if the bleed valve is open). Should I try bleeding at the cylinder by loosening the fittings, since there is no bleed valve?
Any help would be appreciated.
Brett
Brett
S/V Liberty
1980 Morgan 461
Old 03-02-2011
jrd22's Avatar
Courtney the Dancer
It can be a long frustrating job trying to get the air out, I think I would try bleeding the cylinder fittings since I assume the cylinder was empty when you installed it? I've had fluid come up and out the fill on the pump like you describe, probably from air that was compressed while turning one direction expanding when you turn the opposite. I don't know of a simple, easy way to bleed it, I've always just tried everything I can think of and generally made a big oily mess before getting it all out. Have lot's of oil zorbs handy. Good luck.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 03-02-2011
Yes, lots of oil zorbs are definitely appropriate. I can never leave well enough alone. The small drip the cylinder had was not bad, but no, I had to have it perfect so I rebuilt it with new seals and now I am paying for my perfectionism.
Brett
S/V Liberty
1980 Morgan 461
Hydraulic steering wookie Gear & Maintenance 4 12-05-2009 04:11 AM
Hydraulic or Cable Steering? windtraveler Gear & Maintenance 11 11-13-2009 02:05 PM
hydraulic wheel steering clarity36 Gear & Maintenance 6 07-14-2009 08:21 PM
How to bleed hydraulic steering? I33 Gear & Maintenance 4 01-31-2009 09:13 AM
Hydraulic Steering eyebbober Gear & Maintenance 0 09-22-2004 02:34 AM
