Old 03-03-2011
Liveaboard in Florida
PopeyeGordon is on a distinguished road
Lightbulb Any ideas for solar hot water to main h/w tank?
I plan to live aboard a 30 footer in Florida, first choice being a catamaran. I am a big fan of solar technology including solar powered propulsion. Also want to form ideas for using the typical engine heat exchanger in the boat's hot water tank to transfer solar heat from some sort of deck installed solar collector. I would also have the simple solar bladder on the stern for post swim rinsing but since I want to live aboard and anchor out a lot I think there is opportunity to have hot water for the galley and head, saving the reliance for regular engine running to give hot water.
Am I overthinking this, is it enough to just keep a solar bladder on deck over the galley area and use a gravity feed to the sink? Or have you seen a system that takes advantage of the boat's insulated h/w tank and main water system pump to patch in water heated on deck?
Some solar collection panels I have seen look too fragile for topside mounting. How about a 3 gallon aluminum or galvanized tank on deck in the sun, painted flat black, to collect and transfer to the h/w tank below? Or a loop of black tubing around the top of the Bimini cover that circulates to the h/w exchanger coil? It could use a small pump to circulate through the heat exchanger coils, tapped in at the intake side of the tank with a Y-valve that would shut off the engine coolant loop.
Old 03-03-2011
Why make things more complicated than necessary. Keep a solar shower or similar setup on deck...use as needed. Duckworks sells a pressurized bug sprayer with a handheld thumb-trigger shower head that is a nice setup for just this purpose.
Old 03-03-2011
As I originally stated, I will use a simple solar shower on the stern. My post is wondering how to take advantage of the sun to have hot water in the galley and head without relying on the engine or heating water with fuel on the cook stove. Do boaters in the tropics not use hot water? It seems to be useful for washing dishes, scrubbing greasy hands and shaving.
Old 03-03-2011
The bug sprayer setup I mentioned would allow you to use hot water wherever you need it... Just leave the sprayer sitting in the sun during the day... the water can be surprisingly hot by the end of the day.
Old 03-03-2011
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
I keep my solar shower full at all times and exposed to the sun.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 03-03-2011
Irrationally Exuberant
arf145 is on a distinguished road
I wouldn't want to mess with, and possibly jeopardize, my engine cooling loop. But how about putting in another 5 or 6 gal tank to serve as your "pre-heater"? Have the output of the solar tank feed the input from your regular hot tank. If you got your solar tank with a heat exchanger in it, you could set up a closed loop system. That pump is going to be using some power though.
Don't know about the collectors. I don't think just tubing, black or otherwise, would do it. Need a plate, even if it's just copper foil, and a cover to capture the heat. I wonder if this small collector would be enough?
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 03-03-2011
mitiempo's Avatar
I live aboard year round - not in the tropics unfortunately. I have pressure water but cold only. I heat up some in the kettle for washing dishes etc.
Shaving? Good time to cultivate a beard like Joshua Slocum.
Any ideas for solar hot water to main h/w tank?-slocum-hat-spars.jpg
Brian
Old 03-03-2011
Thank you arf145 for the ideas.
Although there may be an efficient pump made for such use that could be switched only when the water warms, I like the idea of the preheater tank on deck - and perhaps the simplest possible arrangement is to have a bypass valve that routes demand past the main hot water heater, through the on deck tank, and to the cabin sinks. Home systems with heat exchangers rely on large tanks, 40 to 60 gallons, that can build up a thermal reserve for the night. Our boat tanks average 10 gallons which means an elaborate system could be of dubious value.
A bypass to the small deck tank would do two things - keep the tank always full, and make use of the convenient on-demand water pump system. Most of the year, the deck tank could be left on since it won't cool excessively at night. The shower bladder could still be used if more water was needed but I like the idea of not lugging a heavy jug in and out of the cabin.
Old 03-03-2011
Thanks to Brian for that great Slocum photo!
I have done the camping thing many months aboard and am not too lazy to heat water on the stove. My reason for the thread was to form a plan to take full advantage of solar power and save fuel. I will be on an extreme budget most of time. Hot water is easy to come by with marina power. Solar showers are the most popular choice on the hook but we live in a creative time so let's think of more ways to enjoy the convenience of hot water.
Old 03-03-2011
Mark F is on a distinguished road
Hi PopeyeGordon,
How about a large, black, sealed spinnaker pole? Or two.
Are there any ideas anyone might have about blue water in a cat 22 closehauled14 General Discussion (sailing related) 63 01-18-2010 08:35 PM
need ideas for gravity feed diesel tank piav Gear & Maintenance 11 11-13-2009 12:40 AM
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 05:38 AM
Refrigeration -Using the water tank as a cooling water source HenryRusty Gear & Maintenance 7 03-29-2007 12:14 AM
ideas for mounting solar panels on a 32 ft. sloop kmeeks Gear & Maintenance 3 12-14-2003 10:15 AM
