Old Lewmar Winch Handle Replacement - Page 2 - SailNet Community
post #11 of 19 Old 03-09-2011
Originally Posted by L124C View Post
5/8 of an inch is snug. I'm guessing 9/16 would be about right. Edit: Just read a post that referred to the old Lewmar's being 5/8, so maybe 5/8 would work. My calipers read 5/8, and are able to move up and down in the hole. I thought the extra material of the shank might require 1/16 clearance, but maybe not.
My winch handle measures .660" from flat to flat, so I'm guessing that it is the right size as it fit loose in my standard winches. I more precise measurement would be better to ensure proper fit. I'll remeasure mine in the morning to be sure, now that we seem close.
Kary
75R20 is offline
post #12 of 19 Old 04-18-2011 Thread Starter
L124C's Avatar
Originally Posted by Jeff_H View Post
For what it is worth, those old Lewmars used handles with square drives and not a star pattern. (I have a few left on my boat) It would be pretty easy to buy the right square barstock and some flat stock and make bronze handles for those winches. It is basically a weekend job with the right tools and a little skill.Jeff
So the original handles were Bronze? I'm having some handles made, and the machinist wants to know what to make the shank (male part) out of, so it doesn't abrade the winch. It's a pain to take a winch off the boat to show him. Anyone know what the female part (star pattern) of the old Lewmars were made of? I wonder why the handles are now made of aluminum, Cost?
L124C is offline
post #13 of 19 Old 04-19-2011
Moderator
Jeff_H's Avatar
I only suggested bronze since it is relatively easy for an amatuer to work with and it was the material of choice before the 1970's. Aluminum was used because it was cheaper and made a lighter winch handle.
Efforts to lighten winch handle weight has always struck me as a little odd since it did not seem like weight was all that significant, but there has always been a pattern toward reducing winch handle weight which is why the cross section of a winch handle is often a channel, there was a period when bronze winch handles had lightening holes, and you now see carbon fiber winch handles.
As to the square drive, it was often made of monel or stainless steel. These are generally harder materials than bronze. That said, I have used winch handles which were cast aluminum (including the drive which in that case was the star pattern) and winch handles which were all bronze including the square drive.
Jeff_H is online now
post #14 of 19 Old 04-19-2011
OK, we can make these if there is a need. I'd suggest a square drive made from SS attached to a body of G10 composite for weight. Use ceramic bearings in the handle or maybe just a teflon bushing.
Of course, it needs a locking mechanism too.
Frogwatch is offline
post #15 of 19 Old 04-20-2011 Thread Starter
L124C's Avatar
Thanks Jeff. As I assume you know better than me, in any type of racing weight is the Anti Christ, often to the point of obsession! I use to race bicycles and would watch people spend lots of time and money eliminating a few grams from the bike, while I was certain the same investment in improving their riding skills and/or conditioning would have been far more effective. I don't race my boat in any thing more serious than a Beer Can, but if I did, the most weight I would need to eliminate is off me, thereby helping me and the boat! I'm in world class form as rail meat though (just in case Larry Ellison is reading the thread)! So...the weight of the winch handle is the least of my worries! Thanks again!
L124C is offline
post #16 of 19 Old 07-20-2013
Re: Old Lewmar Winch Handle Replacement
I realize this post is a couple of years old, but like a the original post indicated I to am stuck with old style 5/8 inch Lewmar winches. I'm new to sailing so any advice would be great.
mechengr is offline
post #17 of 19 Old 07-20-2013
windarra44's Avatar
You might want to also try HUTTON-ARCO Australia www.huttonwinches dot com. They bought out old inventory and manufacture parts for discontinued Barlow/Barient winches and list Lewmar. I have 8 winches on my boat, a mix of Barient and Lewmar, they've been very helpful.
Good luck.
Steve
If you don't like something, change it. If you can't change it, change your attitude.
Maya Angelou
windarra44 is offline
post #18 of 19 Old 07-20-2013
Thanks for the prompt response. Looks as though they will be able to help.
mechengr is offline
post #19 of 19 Old 07-21-2013 Thread Starter
L124C's Avatar
If you look at the OP, I've added a edit that provides a link to a company that makes replacement handles with a star or square spline pattern.
As I often say, when it comes to sailing, there are few "stale" threads. After all, my OP is certainly newer than the winches you are trying to find handles for! I found the company (actually, they found me) through another related "stale" thread.
L124C is offline
Old winch handle replacement L124C Gear & Maintenance 33 07-01-2014 03:17 PM
5/8" Lewmar Winch Handle Soontobecruiser Islander 7 04-20-2012 12:28 PM
Looking for an old winch handle j1brady Gear & Maintenance 22 10-01-2010 08:37 PM
Looking for old Lewmar 5/8 drive winch handle Soontobecruiser Gear & Maintenance 0 06-21-2009 08:44 AM
winch handle marthajewel Gear & Maintenance 7 02-25-2009 10:57 AM
