Old 03-05-2011
trippinocean is on a distinguished road
Westerbeke w30 parts?
Looking for a new or rebuilt fresh water pump and pulley cap for my westerbeke w30 engine.
part number 17909 pump
part number 13862 pulley cap. Does anyone know where to get one other than the factory since it costs $720. Thanks
Old 03-05-2011
Allanbc's Avatar
Allanbc is on a distinguished road
I've used Discount Marine Source
They have cheap shipping and a little better price. The only problem with them is they are often slow to ship. I use them for parts I don't need right away.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 03-05-2011
MARC2012's Avatar
MARC2012 is on a distinguished road
Was told good source,leyland parts,1-800-900-7224.That is for tractor parts should be the same.marc
Old 03-06-2011
IanMcGoo22 is on a distinguished road
I agree with Marc 2012. The Westerbeke 4-91 and W-30 are marinized versions of the British Leyland B-Series diesel. You could just google "Leyland Tractor Parts" and probably find a bunch of places that could help you, or maybe even find one on E-Bay.
Best regards
Ian
Old 05-27-2011
Wetass is on a distinguished road
I know his thread is a couple months old, but just in case - The water pump can be had really inexpensively from ASAP-SUPPLIES in the UK. As can a great many parts for the W30. Its the same engine as the BMC1.5. Westerbeke added on a few marinized parts of their own design like the exhaust manifold, but most parts and internals are the same.
The water pump changed over the years. I found the best way to tell was by the number of bolts on the cap along with the diameter of the impeller. You can also look in the manual and there should be a list of changes and dates - from that you can figure it out as well. My '81 used the 4 hole 70mm impeller. Go to asap-supplies and then do a search on BMC 1.5 Water Pump - Currently out of stock, but they can get it for you.
Old 07-27-2011
mga9400 is on a distinguished road
Water Pump on Westerbeke 4-91 , aka W30
The water pump on the Westerbeke 4-91, aka W30 is a Jabsco pump. If you call jabsco with the Westerbeke part number, they will give you their number. Maybe you can then google it for another source. I ordered it from West Marine and it about half the Westerbeke price; but it took a long while. The West Marine special order desk
can be reached at 888-888-3221. Give them the Jabsco part number for a quote and availability report.
Old 07-27-2011
MARC2012's Avatar
I think he is referring to the fresh water pump.marc
Old 07-28-2011
sidney777 is on a distinguished road
Try Sailboat Hardware, Sailboat Engine Parts and Boating Supplies - Torresen Marine - The Sailboat Specialist they have parts and are friendly. Muskegon, Michigan
ph 231-759-8596
Old 08-08-2011
MARC2012's Avatar
do not know re cap but pump can be rebuilt,commercial water pump rebuilders,ph 713-864=5199,around 90 dollars.Just had mine done waiting on return.marc
Where To Get Parts For Old Westerbeke 4-107? BELLATRIX1965 Gear & Maintenance 9 11-17-2010 03:40 PM
Perkins / Westerbeke 4-107 vs. 4-108 Parts? BELLATRIX1965 Diesel Engine Forum 4 02-06-2010 01:07 PM
Westerbeke four-91 parts bluwateronly Diesel Engine Forum 5 10-07-2009 08:22 AM
Westerbeke diesel parts-WB 13 dolce06 Gear & Maintenance 4 01-11-2008 09:15 AM
old westerbeke parts mpal Gear & Maintenance 1 04-26-2001 07:18 AM
