Old 03-05-2011
chrism33's Avatar
chrism33 is on a distinguished road
How can I seal a anchor chain deck pipe?
Hi folk.
I have this anchor chain deck pipe on my boat. (I think it's called a spurling pipe?)
When there's a bit of a sea, it lets water in.
I've had some sucess stretching a neoprene beer cooler over it but it eventually washes off
.... ignoring my warm beer problem.
Any ideas?
ChrisO
Last edited by chrism33; 03-05-2011 at 09:25 PM. Reason: Typographial error - left off the "?"
Old 03-05-2011
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
Zip-tie the beer cooler to it, instead of just stretching it over.
S/V Old Shoes
1973 Pearson 30 #255
Old 03-05-2011
scottyt is on a distinguished road
foam rubber plug with a string to pull it out.
or seal up the chain locker and put a drain it in over board
Old 03-05-2011
fryewe is on a distinguished road
Use silly putty or butyl tape to seal it. They are waterproof, but not too sticky, with the consistency to form a seal that seawater can't budge.
Old 03-05-2011
HUGOSALT is on a distinguished road
Might you be able to turn the cap 180 degrees to help
minimize water intrusion?
Also maybe a PVC cap that could go on top and then
drill a small hole in the side of the cap, insert and knot a small bungy cord to go under your line/rode and attach to
stanchion base. should stay put and not get lost.
I have been told that I may be related to Rube Goldberg!
Hugo
Old 03-06-2011
centaursailor's Avatar
Senior in age only!!!
centaursailor is on a distinguished road
I,v tried most things to prevent water getting in to the anchor locker. Can,t change the vertical entry directly under the windlass.
My latest is a !/4" rope plaited through the chain to fill the entry, starts wound well enough to fill the entry and continues as a taper and ends a couple of links down the chain when the anchor is stowed. The tail of the rope goes into a plastic bottle to wick away any water that gets though.
Second season and main problem is remembering to empty the bottle.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
Old 03-06-2011
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Would plasticine (a.k.a., modeling clay) work?
Old 03-06-2011
Minnewaska will become famous soon enough
Where does the water in the chain locker go now? If it collects or goes somewhere undesirable, fixing that is where I would attack the problem. Retrieving wet and muddy chain, particularly when raining is always going to introduce some water down there, albeit nothing like a breaker.
Jeanneau 54DS
Old 03-06-2011
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
Mine are big enough to accept a small nerf football. it can stuff in around the existing chain no problem. it can be pulled out easily when you draw some chain out.
Dictated, but not read.
Old 03-06-2011
Gladrags1's Avatar
Sailor
Gladrags1 is on a distinguished road
Minnewaska is exactly right, there should be a drain hole allowing the anchor locker to drain. You need to have a way to remove water brought in via the anchor rode and/or clean the muddy chain and line. Is there such a drain and does it need opening up?
Tod
sealing anchor chain pipe rmeador Gear & Maintenance 2 09-30-2010 06:47 PM
Mast/deck seal SVImpunity Gear & Maintenance 10 10-30-2009 01:33 PM
How to Seal Anchor Chain Pipe Hole mightyhorton Seamanship 21 04-23-2009 01:55 PM
Poly holding tank pipe thread seal surftom Gear & Maintenance 9 06-23-2008 02:55 PM
stove pipe deck fitting and charlie nobels tiptan Gear & Maintenance 1 06-16-2005 08:36 AM
