Old 03-07-2011
rmeador is on a distinguished road
hard bimini?
I see a lot of talk of hard vs soft dodgers, but I can't recall a mention of a hard bimini. I'm thinking I need a bimini. I know many purists will tell me I can't sail with one, but I get sunburned very easily so I think it is warranted (I promise to stick my head out to check the sail trim). I was just looking at the Atkins and Hoyle website (makers of my portholes) and noticed they do hard biminis. Wheels started turning: I want solar panel mounts on my bimini anyways, so it never made sense to me to pay for expensive sunbrella or other fabric when it is just going to be covered with panels. Maybe a hard bimini is the answer? Why do they seem so rare, is there something inherently wrong with them? Also, check this out, from the Atkins and Hoyle website (emphasis mine):
These new products are available with many options including: radar mounts, wind generator mounts, davit option for Arches, rocket launchers for fishing, and many more customized designs.
Ok, fine, so the context makes it pretty clear that this is some kind of fishing device I'm unfamiliar with, but still, some rocket launchers might make those somali pirates think twice...
1979 Gulfstar 37 Laissez Faire
Old 03-07-2011
mitiempo's Avatar
Hard biminis are common. My neighbor is installing one on his Grand Banks 48.
Brian
Old 03-08-2011
chuck711 is on a distinguished road
bimini
Hard Bimini are heavy and can effect sailing ( handling ).
Why not just erect a frame and put up 3 tightly fitted panels to act as bimini?
Old 03-08-2011
CapnBilll is on a distinguished road
I haven't bought one mainly because they cost more, but there are a couple of downsides.
1. the weight, I don't see this as a big deal but something to consider.
2. harder to remove, high winds they act like a giant scoop.
3. storms, for a severe one I take the bimini down, can't with a hard one.
I'm tempted any way, they last longer and rarely leak. I have a hard top for the stern, ( a heavy duty one), that has made several hurricanes no problem.
The Sun has Risen on a New Day filled with the Promise of Adventure.
Old 03-08-2011
mitiempo's Avatar
Weight up high is not a great idea. If you put 100 lbs 7' above the waterline the result is a vertical moment of 700ft/lbs. To maintain the vertical center of gravity you need 700 lbs 1 ft below the waterline or 350 lbs 2 ft below the waterline.
Brian
Old 03-10-2011
Omatako's Avatar
Omatako will become famous soon enough
100 lbs as a percentage of 25000lbs?
0.38%.
Still, I wouldn't have a rigid bimini but I would seriously consider a hard dodger.
Arthur C. Clarke
Old 03-10-2011
mitiempo's Avatar
The displacement of the boat makes no difference to the numbers I posted. But the heavier the boat the less actual effect it has. If you were to put 10 lbs on a mast 70 feet up you would still need the same 700 lbs 1' below the waterline to maintain the stability you started with. Weight up high is obviously more of an issue on a 30' boat than on a 45' boat.
Brian
Old 03-10-2011
Boatsmith's Avatar
BoatSmith
Boatsmith is on a distinguished road
A hard bimini cover could be made of 1/4" foam sandwiched between single layers of 1708. I would think that it would have to be for a pretty big boat to add up to 100 lbs. Sunbrella doesn't last long enough in my opinion.
BoatSmith ---Boatbuilder
Old 03-10-2011
mitiempo's Avatar
Could be.
Looking at a Taratooga (sp) hard top covering the cockpit on a nearby Coronado 35 I am pretty sure it weighs much more than 100 lbs. In addition to the fiberglass top there is the structure to hold it up. Allowing for the smaller size (probably) on a bimini it would depend on how it is built. Of course when you have a hard bimini it is a great place for solar panels - more weight. 135 watt Kyocera panels are 29 lbs each.
Brian
Old 03-10-2011
micheck is on a distinguished road
Would adding lead weight to the bottom of the keel be an acceptable method to counter the moment created by a hard bimini (with 130 pounds of Kyocera solar panels) - say 5' x 300 pounds for the bimini vs 3' x 500 pounds for the keel add on? What does that do to sailing performance?
Hard Bimini Construction LarryandSusanMacDonald Gear & Maintenance 10 09-21-2011 12:33 PM
To bimini or not to bimini that is the question davidpm General Discussion (sailing related) 16 09-14-2008 10:05 PM
Bimini Keerkape Gear & Maintenance 4 02-11-2007 06:30 PM
Hard dodger and bimini S/V Perfect Partner General Discussion (sailing related) 2 05-14-2006 08:07 AM
Hard Bimini c172guy Cruising & Liveaboard Forum 5 10-07-2003 06:56 PM
